Is there a reason to terminate a connection at the binding post vs. the transformer?
See attached schematic.
Audio Research terminates the feedback loop connections at the binding posts. Is there any reason they chose that vs. terminating at the transformer? The area behind the posts is cramped, and terminating the wires at the transformer also reduces overall wire length. I don't want to second guess ARC, I'm sure they have their reasons, but it seems electrically equivalent. Am I missing something?
The 0 ohm tap goes to the - feedback resistor and the speaker (-) return.
The 4 ohm tap is grounded internally. It goes to the 4 ohm + speaker terminal (if used).
The 8 ohm tap goes to the 8 ohm + speaker terminal (if used).
The 16 ohm tap goes to the + feedback resistor and the 16 ohm + speaker terminal (if used).
In other words, the schematic wiring must not change, regardless of whether anything external is connected to a particular binding post.
I would tend to preserve the wiring present and add two internal tie points near the speaker terminals, to replace the eliminated binding posts.
