is there a power supply unit for prototyping?
I'm a noob! be kind this must be really basic. I've ordered a couple of books about tubes already, but i have questions!!
Well, i have a tripple DC power supply unit for powering all the IC's and solid state circuits during prototyping.
Are there units out there that can go up to 300 VDC so i can power power the filaments? if so, do you recommend any?thanks!!
funny thing's will happen if you try to power filaments with 300V......
anyway-google or search e-bay for heathkit or eico supply
electrophoresis is the process they use to map dna in those neat block pattern things you see like on csi and other tv of that kind they make a sort of a film that looks like a negative but they are called gells.
Nick
astouffer said:
Another source of power are the electrophoresis supplies that show up on ebay.
Some great bargains if you can find them in working order. The ISCO 494 does up to 2000 volts or 150 ma (not simultaneously) and works on the basis of three output limit dials - voltage, current and power. Makes it almost impossible to damage devices if adjusted properly. I also have a Helena Labs Titan Plus, dual outputs good for ~750 VDC and if I recall over 200 ma per output, with digital current and voltage metering. I think it cost me about $50.
