I'm looking for a complementary FET for 2SK117.
Is there such an item? If not, can anyone tell me something close?
Thanks and regards,
circuitscc
Thanks and regards,
circuitscc
The 2sk117 has three grades, with three different Idss levels. Y 3mA, GR 6.5mA, and BL 14mA. Arguably there are suitable p-channel parts to act as complements for these three levels, especially the higher two. Which are you thinking of? What are you working on?
The 2sk117 is a discontinued part (although it's not too hard to get) without especially-attractive properties, and it might be better to chose a new n-channel part as well, and work from there. What do you think?
I'm on the same fruitless search as you. (That's how I found your post.)
I'd say "No" at the moment from my enquiries.
May I ask what project you have in mind? Are you trying to get a 'pair' to replace the other low noise Toshiba Fets whose part number escapes me at the moment.....the 74/170 ones....?
Good luck, and let us know if you DO find one!
EDIT: Sorry, second part of your question......J201 and 2SJ103 might be worth exploring.
AmpsLab have a small range.....may be useful...I think they had some complementary pairs.
Jonathan
Jonathan
