is there 17" LCD that do not scale 1024*786
I trying to find a 17” LCD that display lower resolution in there native res. That mean if PC out is 1024*786 the LCD will show black bars on top, bottom, left and right. Resulting in1:1 mapping with black par filling the area.
Is there a way to prevent the LCD from (stretching) scaling the image to 1280*1024 res. either by software or a monitor that has an option of keeping the native res. Without stretching.
The idea behind that is to use a 17” LCD with 12.2” fresnel and to make your pc to out a 1024*786 and the image will be perfect for the fresnel size.
I am planning to use a BENQ FP767-12 or Acer AL1721 (are they diyable).
Please help me to find answer to stretching issue.
PowerStrip is a software soulution if you plan on driving you PJ with a PC. Some monitors will automaticly, or at least via an OSD option, output the correct apect ratio of the source without scaling. Unfortunatly, I do not have experience with either of the monitors your looking into.
