Is stranded steel hookup wire OK?
Assuming that I want to use insulated stranded hookup wire, not solid, are there any disadvantages to using steel stranded as opposed to copper stranded? Copper stranded is much more commonly available, in my experience anyway. Steel stranded is much cheaper than copper, but it seems that most people shun steel in favor of copper.
By the way, I've never run across solid steel hookup wire. That would be, I suppose, because it wouldn't be very flexible?
Regards, Pete
Just how much wire are we talking about? Are you re-wiring your house or wiring up a headphone amp?
If you are dealing with hundreds of metres or kilometres, then the price difference might be of significant. I wouldn't want to be the one pulling through the joists... Plus, if you are re-wiring your house, you might want to look into the local building and safety codes for electrical -- I know where I live the authorities want solid 14/2 copper over other things (like aluminum wire, cloth jacketed, and BX is a no go, and believe it, there are actually people still using that stuff because they find it at a garage/dump sale).
Copper is a better conductor than steel. Steel is much stronger under pull like in phone wires or antennas. Copper clad steel is used for applications that the wire is under that I kind of pulling force an still needs the conductivity of the copper.
I have come across so called 'Copper Weld' used in the core of flexible miniature co-axial coiled cable for external Cellular Phone antenna connections. It wasn't for cost reasons but was for strength. How the copper was bonded to the steel I don't know, magic perhaps.
I'm guessing the strength with flexibility is why they use it in CATV co-ax pointed out by the earlier post.
I guess that using it for military field telephones was again for strength, less likely to get damaged when driving a tank across it.
The copper coating is very useful for crimping to or soldering.
Skin effect, at the high frequencies of both the CATV and now digital, and RF dont see the impedance that an audio range signal would. And when they put the CATV network in the UK in the 90s, there was also caost and durability to think of. Its good fun trying to pull a big cable down a main road at 4 in the morning.
With F connectors the core forms the hot pin, the shielding is crimp bonded to the housing with 360 degree coverage if they are preped and crimped properly. Most of the main routes have now been replaced by fibre.
Military wire, most things designed for the basic soldier to use have to be almost indestructable and then some...copper wire and running squadies wouldn't mix, and in this case skin effect isn't a player, voltage is, its the plain old telephone system, restricted audio bandwidth, remember the phone calls of the seventies and earlier, the message got through.
My understanding of hook-up wire is that it is the small stuff, that is, like 24 AWG to 18 AWG. I don't know I suppose that house wiring may be referred to as hook-up wire. But anyway I was focusing on wiring such as that of a headphone amp.
The point is well taken that there is going to be little cost savings unless there is a lot of wiring length involved.
Also I didn't realize that the resistivity of steel is much greater than that of copper. A table of resistivity that I found lists the resistivity of "average" (whatever that is) carbon steel as more than ten times that of copper.
Regards, Pete
