But we havn't even scratched the surface of the audio improvements you can get by using a USB hub especially when it is disguised as an audiofool device and surrounded by some wonderful mystique... Though if I was cynical I would suggest that someone has seen and created a niche market so they can suck more money out of gullible audiophiles and every man and his dog is jumping on the bandwagon to bring devices to market, but I am not so will bask in the wonderful anecdotes of the vast improvements these devices bring even when measurements and sanity would suggest otherwise.
Yes, several of us presented data. That's not useful for stories, but it is quite useful for determining facts.
Ground plane and power plane noise data?
USB PHY current surge/power-related noise data during bit-determination with the usual signal integrity issues?
And this during async USB real-time streaming, which isn't the same thing as file transfer contrary to what you erroneously implied?
A quick forum search will turn up the thread. Nearly everyone's DACs sailed through it. This is a very mature technology everywhere but among the voodoo crowd.
Except you have completely missed that I was telling Gino about issues other than what that J-test result set provides, so it isn't even relevant.
I will admit that asynchronous USB is not necessarily perfect in sound quality, and that paying attention to certain details can improve the sound quality of USB audio interfaces, both on the sending side, and the receiving side. I would not say this is "jitter", perhaps it is just due to noise transmission to the analog side of the DAC circuitry, or ground plane noise affecting the audio clocks, or... Well isolated USB interfaces with separate supplies help when well implemented.
Attention to details in these interfaces, which many respected engineers feel do not matter, often result in improved sound quality.
What has recently come to my attention, is that using a very low phase noise clock for the USB processor even improves sound quality, yes I know this sounds totally ridiculous, and I have no technical explanation to offer.
Sorry, just some of my experiences reported here.
Someone was asking for someone else who knows to enlighten, here is one. barrows knows.
Interesting stuff about the clock, barrows. I've not yet experimented with those, but I've done some really easy variations around signal integrity as well as the ground plane where the SQ effects are obvious and higher than what one would expect.
None of which matters a jot if the output from the DAC is clean down to -120dB. If there is a problem in the input it will be seen on the output. Not seen then no problem, other than in your mind!
Async USB audio just sends data, protected by a CRC. Something has to be seriously wrong to get data corruption, and it would be very noticeable when it happens. If it is not happening, then the data is perfect. Whether the DAC then does a good job of turning perfect data into an analogue signal is a separate issue, and would be unaffected by USB cables etc. (apart from the usual audio issues like ground loops).
This is a boring story, and will not lead to sales or exciting magazine articles.
It's not about data corruption at all...
I didn't miss it, it just seems to be irrelevant. Do you have any data beyond stories and handwaving?
Where's the analogue signal!!!!!!!!!
I can not believe the blind ignorance this thread is promoting...
USB audio signal is a digitally encoded analog signal stream in nature, sent down the twisted pair transmission line cable.
The only digital signal that I know of is either ON or OFF signal, like in PLC digital input cards, where +24V means ON, and 0 volts means OFF.
Nick
Care to explain to us idiots for whom USB appears to be very digital caring little about absolute levels as long as they are within the spec. For USB2 0.38V and 0.42V are both 1. Nothing analog about it.
Then send that digital signal of yours down the figure 8, un-shielded cable, like one you'd use for speakers. According to you knowledgeable fellas, it is only USB digital, right?
Nick
How is a digital stream of ones and zeros coming out of the USB a different 'digital' that the stream of ones and zeros in your PLC then?
Jan
Jan
One could discuss the intricacies of bit stuffing working nrzi encoding, but I don't think that's central to your point. You can still look at USB protocols as edge clocked, so that says digital to me.
Google is your friend…
USB 1/2 are half duplex using one twisted differential pair and 3 is full duplex using two twisted differential pairs. The signaling is digital using differential drivers and receivers.
There are a number of parameters that are measured to confirm a cable meets requirements but differential impedance, skew and insertion loss are the most important for proper operation especially for USB 3.0.
The differential impedance of the cable assembly (twisted pairs + connector) is supposed to be tightly controlled. The certification mask for the connector to cable interface and the connector to connector interface loosens a bit. A differential TDR or Vector Network Analyzer with special SW is used) The time skew between the + and – wires of each pair must be tightly controlled. This is measured with special equipment. If the cable loss is too high due to crappy quality cable or too long a cable, you will have problems. If the skew between the + or – wires of a pair is too high, you will have problems.
Building cables to meet all the requirements in the certification document and at the same time being cheap is nearly impossible. You can start out with good cable and connectors, but the fabrication time required to meet certification is too high to meet cost. In general companies make “gold standard cables” to be submitted for certification.
You do know that USB 1.x and 2.0 is un-shielded? However as it is a system rather than a cult the cable parameters are clearly defined in terms of twisted pair and characteristic impedance. Meet those and it will work.
USB 3.0 to hit gigabit rates has Shielded cable.
Crosstalk is the main reason the two USB 3.0 twisted pairs in the cable are shielded. The USB 1/2 twisted pair in the same cable is not shielded. All require a DC common to keep CM low.
Careful, you'll confuse the believers
Jan
One carries audio signal.
- Digital Line Level
- Is jitter an issue with usb signals ?
