Sorry to be a bit acid, but am really very tired of the classic audiophile "not-good-enough-for-my-gold-plated-ears" argument regarding digital stuff, and basically this is what the sync/async debate is all about.😡
That is certainly not my understanding of the debate. My understanding is that USB was originally never intended to do anything other than transfer data. However, a standard was later issued by which it can transfer audio data with some degree of timing accuracy, but this is inadequate for critical purposes. As it is usable for audio, people use it but then talk nonsense about cables etc. (as in all facets of audio!). Meanwhile, for serious audio people just transfer data via USB and then everything is fine.GDO said:Sorry to be a bit acid, but am really very tired of the classic audiophile "not-good-enough-for-my-gold-plated-ears" argument regarding digital stuff, and basically this is what the sync/async debate is all about.
Could someone who really knows pop up and enlighten us all?
Go, sure you are the one...
Thank you for sharing with us your knowledge on this matter.GDO said:Go, sure you are the one...
I don't know; there were too many TLAs, but it appears to be something which sends audio data to a computer via USB. If so, completely irrelevant to this discussion - which I believe is about audio data coming out from a PC.
Yes, you are what i feared you were: an audiophile! 😀
Data that come out from a pc are data that also have to come into a pc, that's what recording is all about these days, and both things must be done in a synced way, asynch being an unacceptable form of anarchy in a studio...
Usb soundcard made recordings suck: always require the PCI label!😀
Well, before I admit to that I would need to know what you mean by "audiophile" and whether you use that word as a meaningful label or merely an insult.GDO said:Yes, you are what i feared you were: an audiophile!
Once again I must thank you for sharing your knowledge with us.Data that come out from a pc are data that also have to come into a pc, that's what recording is all about these days, and both things must be done in a synced way, asynch being an unacceptable form of anarchy in a studio.
You understand, of course, that a PC deals in data and data alone so any timing information associated with the audio must be stored as data too (or, to be pedantic, perhaps it should be called metadata). I still don't see the relevance, unless you imply that a PC running a non real-time system such a Windows (or Linux) can accurately timestamp data entering via USB - not just data packets but individual data samples. Studio operations must of course be synced together, but a PC is the last thing I would consider for doing anything other than storing data in the correct order. I speak as someone who spent a career working on real-time systems using real computers; PCs were regarded as some sort of a joke.
Time stamped audiophilia, bit perfect Klan, packet loss Holy Inquisition... Sorry, you are too much!😀
I belong to the crap vinyl generation and never minded the ... about wow and flutter. Similar with jitter and whatever digital miseries...😀
"Time stamped audiophilia, bit perfect Klan, packet loss Holy Inquisition... Sorry, you are too much!"
I am struggling to find anything meaningful in that sentence.
I belong to the crap vinyl generation and never minded the ... about wow and flutter. Similar with jitter and whatever digital miseries..."
So what contribution do you think you are making to a thread on digital and USB?
The helpful way in which you share with us your detailed knowledge of USB audio technology is an example to all.GDO said:Time stamped audiophilia, bit perfect Klan, packet loss Holy Inquisition... Sorry, you are too much!
That was my meaning yes, thanks for the clarification. I didn't mean to imply that clocks suddenly became irrelevant simply because the transmission medium was async USB.
I know you know but some in this thread (and elsewhere) has no clue or are only guessing so better be precise.
USB is really problematic. When I try to print documents, the words get scrambled or typos suddenly appear.
For every audiophile neurosis, there's plenty of story-tellers delighted to feed it.
A very common mistake by the uninformed: file transfer isn't the same USB mechanism by which asynch USB is used for audio...
In sync and for file transfers, there is CRC + re-send.
There is no resend in async USB for audio!
In other words, you are comparing apples to oranges.
Where can I buy an "analogue USB cable"? My local shops only seem to have the nasty digital USB cables.
Any normal USB cable, DF96. It seems you are ignorant about how USB cables transmit voltage levels with ramp up and ramp down times...
I am also struggling to find any meaningful reasons for audiophiles deepest fears regarding issues like jitter and stuff like that they have read about...
I always look also at the professional sector.
For some things, the pro sector is far ahead the audiophile ones: just look at how many people use passive crossovers rather than strive for bi-amping with active ones as an example.
In the pro sector where mixing and mastering is very important, we use active, bi-amped monitors for good reasons.
You haven't seen the real debate. 😛
We're not even debating sync vs async anymore: we're debating why the async wasn't perfect the first time around and why we can still today eke out better SQ even with an async implementation.
This discussion is tame compared by what you can read on some forums. 😀
This post just confirms how uninformed of the general subject you are. Voltage ramp up... cheeeshhhh... You are spreading irrelevant / false information - just so you know. DF96 know about 3x10e3 more about this than you - you are making a fool of yourself. GDO is right behind you apparently.
Not inadequate, just not perfect as it was thought it was already once async was implemented.
OK, let's see YOU explain what travels in a USB cable since you haven't learned about it and are probably just making erroneous assumptions.
DF96 already made some basic mistake, just as SY and that other troll who wrote 'condesending'...
Bufff, these audiophile calvinist debates screw... 🙁
Go to hell with your async ... pumps if feel comfortable enough with them...😀
https://www.youtube.com/watch?v=1xc4Vx1oXoc
Sorry, I don't consider you to have the basic knowledge to discuss timing architecture in digital audio systems.
SY and DF are only pulling your legs.... cant you see that? No... probably not....
But I pass this: You are lost in a forest and the only thing in your possession is a compass but you keep wondering why there seem to be some water in it and spend time on how to get it out... this is you in digital timing land.
- Digital Line Level
- Is jitter an issue with usb signals ?
