Is it worth potting the transformer and PSU caps of my Firstwatt f2
Hey guys
I did a Firstwatt f2 build a while ago. Just adding some final touches now.
It uses a not particuarely fancy transformer, which just has a wrapped thin clear plastic coating around the wire wrap.
Would it be worth removing the plastic wrap and soaking the whole thing in glue/epoxy?
For reasons that i cant remember, we raised the resistors and caps off the PSU board. Is it worth epoxying under them to restrict any movement?
Hugz
Bob beat me to it.
I wouldn’t pot the transformer in epoxy because of magnetoconstriction (vibrations caused by expansion and contraction of the core which occurs at each change of flux linkage, that is, twice per mains cycle). If you restrict the expansion and contraction of the transformer core this will reduce the inductance of the core and increase heat dissipation. Additionally potting will reduce the airflow cooling the core and increase its temperature. If you want to glue the transformer and capacitors to the board to keep them from moving I would suggest silicon rubber glue which allows for the expansion and contraction. This will also make removal much easier in case of parts failure.
