Last night I played with TubeCAD (I'm lazy) cause I wanted to put my 6SN7 to good use. I configured it in SRPP mode given the following conditions: 320V B+, 8mA
According to the results, I'll get 11.29 Av, -3.9 bias, +-44V Vout
So I went ahead and ripped off the 6SL7 circuit from my 2A3 and wired in the 6SN7
I wire the lower tube's cathode with two LEDs instead of 470R resistor.
When I got to play the amp, I immediately noticed the lack of dynamics and resolution. It was disappointing. Boring sound
What have I done wrong?
I've configured this amp to use the Sun Audio circuit (2 stage 6SN7) but did not like it as well.
LED bias works best when the anode load resistance is high - SRPP puts a quite a low load resistance on the lower valve.
The 6SL7 removed from your amp has a higher Mu of 70 as opposed to the much lower Mu of 20 of the 'SN7.....
I prefer the sound of the 'SL7 to me, Much more dynamic...
Alastair, yes I was wrong. I thought that having a lower mu tube (I have a preamp) with much more current could improve the dynamics from that of the 6SL7.
I listened to it again last night and it was butchered by my 45 amp with 5842 as drivers.
