Is it possible to cover the whole spectrum, high SPL, low distortion with a 2-way?
"so there is no "reflection" and what comes out of the mouth is clearly "direct"
Waveguides are non diffracting horns....
The words Diffraction horn throws me because I thought a diffraction horn was only a horn that had a diffraction slot. That apparently isnt true exactly. The more I study the words Diffraction the more I can visualize it...A loading horn can be free of diffraction is what I think I know at this point lol , as well, diffraction can happen with a horn regardless if there is a slot....its just a matter of where the Diffraction occurs
Quarter wave tuning is a result of Reflections? Thats not the right question....Quarter wave tuned diffractionless horn..is this output considered a mix of direct and indirect energy???
Does this mean that the added directivity and seemingly increased radiation size of a wide baffle with woofer, does or does not belong to the class "reverberant field"?
I think with both situations horn and wide baffle, the waves are synced in time but I am not sure exactly how to define "Synced"
"But they are not synched in time and that makes all the difference" This is likely what I need to break down.... It seems that to be considered apart of the reverberant field...the wave must be delayed by at least a certain amount of time? What is that threshold?
By the way, an exponential horn doesn't necessarily have to be synonymous with 'beaming'.
The link is broken so I am not sure what method you are referencing.
There are right and wrong ways to do ground plane.
The right way is a pit into which the system is installed such that it points up in an truly infinite baffle. Microphone is in the air above.
Placing the system on the ground with the microphone also on the ground is not really correct since there is a lot of absorption as the wave travels across the ground and you are really measuring two systems stacked on top of one another.
Not putting the microphone on the ground is the worst situation and will not yield anything like the real directivity.
Reactions: neo2015
You can determine the dimensions of a room or distance to a boundary required to obtain ‘anechoic’ data to a specific frequency. It’s based on the source and microphone positions, which should be chosen to ensure that the device is in the far-field, if you don’t have a fancy $100k tool like the Klippel NFS 😀
You also have to be relatively careful when choosing the point of rotation, as the acoustic centre and acoustic origin may move farther from or closer to the mic at each measurement position.
This is a very good read, with some simple maths to figure out the limits of your living room, or garden, or whatever:
https://www.audiomatica.com/wp/wp-content/uploads/appnote_002.pdf
Chapter 12 of the CLIO manual is good for single plane polar data gathering methodology, too:
https://www.audiomatica.com/wp/wp-content/uploads/clioman125.pdf
Reactions: camplo and neo2015
Groundplane method is usually interesting for frequencies below 200Hz. It will give a wrong picture with higher frequencies especially when you take diffraction etc into consideration.
The absorption of those lower frequencies is very minimal, but an hard surface is best.
The rest can be done with just a time-window measurement.
In fact a nearfield with simulated bafflestep stitched with farfield time windowed measurements is in most case enough.
But hell, why not all three methods?
Doesn't take that much time (yes I have done it multiple times)
