Is it possible to cover the whole spectrum, high SPL, low distortion with a 2-way?
Whenever "energy storage" pops up, I am often reminded of an old interview with Joachim Gerhard, from which this fragment was copied:
Question: What would you like to improve with low range drivers?
J.G.: We would get several advantages if we could increase the effective area of the driver without losing control over the radiation pattern. And also lowering the mass, make stronger magnet systems and harder, lighter cones.
Question: Many "old" paper woofers still sound astonishingly good compared to modern drivers?
J.G.: Oh, yes. We have not always went to the better. What many driver manufacturers have done the last years, is to increase the damping to make the frequency response more flat. But some old drivers, like the famous 6,5" paper woofer that Jan Paus at Seas made several years ago, (The Seas CA 17 RCY, ed. note) was optimized for low loss. So they made a compromise between frequency response and sensitivity. This driver was very good, and was used by Wilson Audio for many years. Later, in the 80's, manufacturers started to add more mass, they added more damping, and they made surrounds with high loss. That gave an extremely flat frequency response, but also a lot of energy storage. This compared, the old drivers were much quicker. They had some resonances, but you could get rid of that in the crossover. It was this run for flat response that gave a lot of modern drivers this dull, uninteresting sound. And you can also measure higher second and third harmonic distortion in some of them. If you compare the on-axis response between an old and new driver; you will see that the energy in the treble is far higher than in the new drivers. These so-called "modern" drivers often has a Qms of maybe 0.8 or 0.6. The old drivers had Qms values of maybe 5 to 7! We found that drivers with a very high mechanical Q sound more open, more clean and dynamic. And when you look at it, you find it is very simple, because they have less loss. The surround is easier to move, the spider is better constructed, they have better air flow, higher sensitivity. So a high mechanical Q is a very good indicator of energy storage behavior. This is one of our secrets. One of the many!
Not much real science there, but then "stored energy" is not a scientific term so I guess that's to be expected. The only way that I know of a system storing energy is in a resonance. But then this statement " That gave an extremely flat frequency response, but also a lot of energy storage. " does not make sense since a flat response means no resonances. For this statement to be true, the time-frequency relationships that have to hold for minimum phase systems would have to be violated. Most speakers are minimum phase systems.
Joseph, you might want to experiment with a composite polyester/mylar diaphram that has an additional thin film surround. This may (or may not) reduce the leftover resonances at the low end.
That didn't make sense to me either. If I had to guess, I think the article was miss-quoted. I prefer the term "stored energy" since it helps people connect the dots between a frequency response peak and the cummulative effect in the time domain. It's the stored energy which manifests later in time. Many don't grasp this aspect as evidenced by so many people highly focused achieving a flat on-axis response using passive crossover notch filters or DSP.
Agreed on the lack of scientific data to support the claims and the original explanation may have been misinterpreted by the interviewer.
Personally, I associate stored energy with reduced efficiency (ƞ0)
I guess resonances also negatively affect (system)efficiency.
Agreed on the lack of scientific data to support the claims.
I guess resonances also negatively affect (system) efficiency.
Resonance and stored energy are exactly the same thing. I don't think there is any correlation to efficiency. The correlation lies in the the frequency and time domain. A spectral anomaly in the decay plot will have a corresponding impact on the frequency response and vise versa. For me personally, to achieve a flat frequency response I need to look at the time domain aspect.
Here is a quote from Joe D'Appolito in his article "Testing Loudspeakers: Which Measurements Matter, Part 1"
Testing Loudspeakers: Which Measurements Matter, Part 1 | audioXpress
In over 30 years of designing loudspeakers, I have found the following measurements taken as a group provide the strongest predictor of loudspeaker preference available to us today. These measurements are:
• On-axis frequency response
• Impulse response
• Cumulative spectral decay
• Polar response
• Step response
• Impedance
• Efficiency/Sensitivity
• Distortion
• Dynamics
His take on measurement aligns with my approach as well.
I thought that you were saying that making the horn more structurally sound was important, but I don't see your data as supporting that.
That's correct. I don't make mention of the horn material or it's structural properties. For me as long as it doesn't resonate any more than other sources of resonance then it's structurally sound enough. My brother thinks the stain or the horn material does effect the sound but I think it's his imagination. He's yet to show me any evidence....brotherly quarrel.
• Impulse response
• Polar response
• Step response
• Impedance
• Distortion
• Dynamics
How do you measure "dynamics"? 1,2, 3 and 5 are just three different ways of looking at the same thing, (give me 2 and I can derive the other three,) and "distortion" in a loudspeaker has been shown to be insignificant perceptually. I would also question if "impedance" has any real audible effects unless the amps can handle it. But that's an amp issue.
Reactions: camplo
I think that's his point. His priority for placing it second to frequency response represents his full appreciation for the all that can be derived by this through the Fast Fourier Transform.
For THD I only use it to confirm maximum SPL.
For dynamics I would love the answer to that question as well. My personal opinion on the matter, which is completely unsubstantiated by any literature or white papers that I know of, is that dynamic range is a function of spectral decay. Since dynamic range would be compromised if the noise floor was brought up due to slow spectral decay. This makes dynamic range a function of the frequency spectrum. If this is actually the case, then a speaker may have only 15-25 dB of dynamic range depending on frequency. Which makes me wonder why so many focus so heavily on 100dB+ of dynamic range in electronics or playback format when the speaker is such a limiting factor.
.... "distortion" in a loudspeaker has been shown to be insignificant perceptually....
I would be very cautious writting this. Although there are reasons to believe that distortion in loudspeakers can not be perceived because of sound masking effect, i can not find any papers on distortion perception done in mid and/or near field conditions where the influence of the room is quite low.
I would love to debate the scientific basis for dynamics, but I think that may take us too far astream of the OPs intentions.
