Hello,
I have a Roland passive volume pedal. I want to transform it into a MIDI USB foot controller. I plan to use a Teensy microcontroller as an analog to USB converter.
However I have a few questions about the analog part of the circuit:
1. Is it mandatory to send some signal to the pedal’s input and take the pedal’s output as information to be digitized or is there some way to avoid sending a signal to the input?
2. In case it’s mandatory to send a signal to the pedal’s input, would you rather recommend to use an AC or a DC signal?
Thank you.
Thank you.
DC, it will just be a potentiometer. However it will likely be log-law, and you would be better with a linear-law pot for digitizing the wiper voltage - it may be possible to replace the potentiometer part of the pedal if it uses standard variety of pot (and not some special purpose one)
The Using USB MIDI contains general information and at the bottom there's a link to a foot pedal controller that might be just what you're looking for: Footsy - Teensy 2 based MIDI foot pedal controller
