Shoot me down in flames if this is a stupid idea but.......
With a fullrange driver sometimes one needs to prop up the bottom end with a subwoofer for the really deep bass for different music or HT use. Usually a subwoofer has a plate amp that can vary the frequency cut-off, a gain control and a phase control; so if your fullrange driver needs a little lift at the top end with a dedicated tweeter why not adopt the same principle and have an amp that can dial-in the upper frequency cut-off point to suit taste, program material, room conditions, driver abilities etc.
Never heard of it being done. Tweeters seem only to be added with a simple passive crossover to a fullrange driver.
Controls could be frequency, slope, and gain and generally to operate above 10kHz (approx)
as most,if not all, fullrange drivers are good to that point.
Just a thought!
plate amps are mostly not of very high sound quality, that is more critical in the higher frequencies than in the lower. But an active crossover (build in or outboard) is often used to adjust volume and frequency range. But i and many prefer a passive network on lower vollumes like with fullrange speakers. On higher volumes multi amping is more relevant than on <50w
Hi 'waxx'
what I have in mind is having the ability to experiment with fullrange drivers by adding some extra low frequency and some high frequency as is required to see whether there is a beneficial effect. I don't wish to add anything in the signal path to the fullrange driver preferring to keep it running clean....as it were. So having an amp with an adjustable low pass frequency roll-off for the low bass and maybe a phase switch (plate amp) that is entirely seperate from the full range driver acts to merely and subtly augment the fullrange driver as needed. I cannot see why this idea should not be applied to the top end. Again an amp (Class A) that has an adjustable frequency high pass roll-off for the top end and with (possibly) a choice of slope available, and again, entirely seperate from the fullrange driver would subtly augment the fullrange drivers top end as needed by either measurement or critical listening.
you could make a set transistor amp for that, that could be very good. Enough examples are found on this site (check the passlab section). But in general it's not done by many. I also don't really see the point of having 2 differen speaker types in the same frequency area. I think that will lead to phase issues due to the different behaviour of the speakers. But i could be wrong.
I would rather make a 3 way system then with the fullrange in a broad range of the frequencies. I'm actually busy with something like that with an old Philips 9710M and a old Seas TV21G woofer i have laying arround where the philips takes the 90 till 15000Hz part and the woofer from 90 till 35hz. I will ad a tweeter, but i'm still researching wich one would fit to do the upper part. most tweeters are build to crossover much lower actually....
But all will be amped by the same amp of approx 10w (to build yet) with an passive crosssover.
I'm quite sure the Feastrex is currently wired out of phase.... Tell you friend to reverse the polarity either at spk binding post side or on the amplifer side and have another listen.
I just heard a Feastrex at a friends place, while the treble are nice and sparkly. The mid and low leaves a lot to be desired. We compare it with a Coral Holey in a small TL and I though the sound was more completed and I prefer the sound of the Holey more. I had those holey in TL for several weeks at my home and I prefer my 2-way LS50. So in the end it depends on tastes.
I also own Fostex Fe108 SOL and a Scanspeak 10F/8414, we'll see how that goes.
Sorry, already check the polarity so that is not the problem.
As a matter of fact, while testing the diy Holey, I notice the vocal was not focus and I checked the polarity was incorrect and we immediately correct it. So no polarity problem was found with the Feastrex during the listening session.
Maybe the Feastrex needs another box, but I do know another friend who has lived with the Feastrex for a while and was not impressed. My opinion is one should heard the Feastrex first before laying out the cash, because that is a lot of cash.
Ok good that you checked the phase.. When the phase is reversed.. The mid and bass becomes very problematic.. I think more effort is needed in the cabinet and tuning.Sorry, already check the polarity so that is not the problem.
Full range is not a fallacy. Though they lack the power and dynamic range of multi-driver speakers, the increased mid-range clarity makes them excellent speakers.
Two points here:
Dynamic range is not just about the maximum volume but the low level detail
You can use full rangers in an array so you can effectively have any power requirement you like
gee, would that have been an obscure reference to the Bose 901? celebrity doesn't necessarily guarantee merit 😱
There are no problems ...only challenges. Merry Xmas!
A man after my own heart!!!!
The 901 is a very very good speaker. Especially the versions without BR. Tight sound, tremendous dynamic range and imaging out of this world in the right room. That Bose managed to completely squander their reputation since doesn't change the fact that the 901 is a great speaker.
Other than that the Design Acoustics D-12 Dodecahedron, Roger Russell's line arrays among others, EPI Microtower 1, the Time Windows, various Lowther constructions, even the curved electrostats are in fact arrays of fullrangeish drivers.
I wasn't impressed by the 901.
9 x 4" (area of a 12") with not much highs or lows.
And I'm not a fan of flat full range arrays either, but oh well.
We all have our opinions !!!!!!!!!!!!!!
Have a great one !!!!!!!
Putting the little bandor 50 into a 2 litre ported cab is hilarious. Bass in the 30s, great little desktop speaker
To reiterate, and add my own emphasis to Norman's comment re the 901 - I didn't much care for them either - talking about the Series I, driven by either Crown DC300A or Phase Linear 400 & 700, so quantity of power wasn't the issue. Yes, they'd play freaking loud - actually used them a couple of times as PA at school dances (remember the sock-hop?) - 2 stacked per side with the 8 drivers facing forward, and we never managed to break a pair - but the sound was gawd-awful to my ears.
If you're talking about the DCM Time Windows, I always thought those were a 2-way configuration - albeit with 2 pair of drivers per enclosure? - and as for the EPI Microtower, does 2 drivers in a bi-pole arrangement actually count as an array?
Ahhhhh.... the 901's
When I first started to read audio rags, the 901 was the king...Always wanted to have a pair of them until that fateful day--I heard a pair of them. Never meet your heroes they say and they were right. They were not my thing, the highs were choppy or not there and the deep bass did not happen--and they had a "blurry" sound to them.
Oddly enough, one of the engineers that worked at Bose in the 1970's built a vertical line array with the Bose drivers and after plenty of EQ later--showed Amar his creation. The design was about the best you could do with the tech at the time but since it did not meet the "sound everywhere" marketing of Bose at the time, it never went anywhere. That engineer quit a few years later.
As far as a single driver doing everything--that won't happen. As others have stated, the closest you could get is to use dozens of them in an array--not exactly "one" driver but at least it can do actual full range if you use enough of them and get the EQ, phase etc. right.
I have a 3-way vertical line array with subwoofers (4-way!) with two 15's crossing at 90Hz to 12 five inch woofers that cross to 20 three inch mids at 350Hz--those 3 inchers cross to 48 ten millimeter tweeters at 6KHz. Takes some EQ of around +7dB at 15KHz to get the treble working and the mids have a peak or two tamed. The subs take care of the bass.
About the closest I've seen is Gozilla's Beta 12LTA with a phase plug in a 4 cubic foot box tuned to 45Hz. It makes it smoothly out to 8.5 KHz then dies quickly so a Fostex FT17 super tweeter can take over with a simple 1uF cap. Granted, you have to be in the sweet spot but the charts/graphs and reports look good.
Since DIY is all about denial, just hook up "helper" tweeters and subs to the "full range" and you are gold. In reality, it is a 3-way speaker but in reality, our ears are not very sensitive above 8KHz or below 60Hz so the modded 12 can run the majority by itself.
For my home theater use, there is no way I'd run full ranges (except 3 or 4" FRs as surrounds) I need a broad listening area so 2-ways, waveguides and subs are the rule. The quest continues though--because that is part of the hobby.
- Full Range
- Is full range a fallacy?
