is a diy version of a Frazier CAT40 practical ?
Frazier's CAT40 (1986 -?) is a very good and coherent speaker - am wondering if a more rugged version using a 10" woofer would be practical with common drivers (?) what did they use for a crossover?
http://www.frazierspeakers.com/download/c40.pdf
http://www.frazierspeakers.com/download/coax.pdf
Beyma 10G200 is a good choice.
All-foamcore horn is fine for small 3" or 4" drivers, but internal pressure in the 10" horn back cavity is very high, so foamcore and laminated cardboard maybe can be used only for the conical expansion parts of the horn. I would go for a multi layer plywood, as the horn is not that big.
