Hello everyone,
I am wondering if I should be concerned that the Simaudio moon 220i has 40w per channel. (class A/B integrated amplifier) I can purchase it for 600 CAD.
If it is a concern, I can purchase a Peachtree Nova 150 with 150w per channel. (Class D integrated amplifier) This one is also for 600 CAD.
Another option that would save me money is the Cambridge CXA60 that has 80w per channel. (Class A/B integrated amplifier) This one would be 450CAD.
I am going to listen to a Moon 250i tomorrow with my speakers, and if I like it I would like to purchase the 220i, but I will wait to see what you guys think about the low 40 watts per channel.
I will not be able to demo any of the amps that I am purchasing, the 250i is the closest local similar amp I could find that a friend of mine is willing to let me try. I have never heard anything from Peachtree so I do not know what to expect, I am also upgrading from a Kenwood M1 and C1, and a Cambridge Topaz SR10, both of these sound similar to me and I currently use the Topaz SR10 as I am trying to sell the Kenwood stack.
These days dealers will usually let you try out the amp for a couple of weeks or so.
You may only get a store credit if the amp is returned.
Hey Rayma, I am buying these second hand online unfortunately, all the amps listed had an MSRP of well over 1000CAD at launch.These days dealers will usually let you try out the amp for a couple of weeks or so.
That depends on your speakers and spl requirements. But for about 95% of the people it's more than enough.
This might give some added perspective.
https://www.audioasylum.com/scripts/d.pl?audio/faq/sets.html
That's really rolling the dice. What if the amp in question doesn't sound good, despite all the glowing reviews?
jeff
jeff
Yeah, unless you already are familiar with the equipment, it's a crap shoot, literally.
Of course, a good piece of equipment can be defective too.
I will be using Audio Physics Yara 2 Compacts, they are 4 ohm I think. I don't remember the Efficiency but its not too bad, 86 maybe.That depends on your speakers and spl requirements. But for about 95% of the people it's more than enough.
For 4 ohm rated speakers, one thing to look at is whether the amplifier power doubles into 4 ohms compared to 8 ohms.
This indicates a good design for 4 ohms.
I will look into that, but I believe it does double, thanks. These amps are the most expensive I will have ever purchased, and the newest too. I used to buy cheaper vintage gear. If it were up to you, would you recommend any of the three on my budget?For 4 ohm rated speakers, one thing to look at is whether the amplifier power doubles into 4 ohms compared to 8 ohms.
The Topaz SR10 has 80 watts I believe, and I am able to crank it pretty high so I am a bit concerned I guess, I will do some testing tonight.That depends on your speakers and spl requirements. But for about 95% of the people it's more than enough.
I will check this out right away! ThanksThis might give some added perspective.
No I don't believe so, I am buying on Canuck or Marketplace. I do not intend to return as any of these will sound good compared to what I currently have. I am buying from sellers with good reviews.Can the used amps be returned if you don't want them?
No I don't believe so, I am buying on Canuck or Marketplace. I do not intend to return as any of these will sound good compared to what I currently have. I am buying from sellers with good reviewsCan the used amps be returned if you don't want them?
It's a risk I have to take I guess, it will still sound better then my current equipment I am sure. I just want to make sure I get the best of the three options. The Simaudio 250i which is very similar to the 220i is the only one I can demo.That's really rolling the dice. What if the amp in question doesn't sound good, despite all the glowing reviews?
jeff
What don't you like about the Topaz SR10 and Kenwood M1?I am wondering if I should be concerned that the Simaudio moon 220i has 40w per channel. I am also upgrading from a Kenwood M1 and C1, and a Cambridge Topaz SR10, both of these sound similar to me and I currently use the Topaz SR10 as I am trying to sell the Kenwood stack.
These are 85w/ch and 105w/ch which is 3dB+ more than the 220i, if you use most of the power you have on tap now then 40w/ch will not be sufficient.
If I buy from sellers with good ratings, the equipment should be decent no? I don't think people would have mistreated equipment of this price range, and they all look to be in mint condition.Yeah, unless you already are familiar with the equipment, it's a crap shoot, literally.
The Moon does double power into 4 ohms, so that's good. But I can't tell you which of these would work best on your speakers.
Often people buy equipment to resell it, so they may not know that much about it, even if they have good ratings as a seller.
On the Kenwood I have never gone to max power, on the Topaz I believe I got close. I will check tonight quick. I don't necessarily dislike them, but I would enjoy more detail and instrument separation, I have been hunting for speakers without boomy bass and people eventually told me I just had bad amps. I have B&W CDM1 SE's too but can't listen to them because I get fatique from it and the Yara's are the same honestly. I have Totem mites as well and they r the only ones that don't give me listening fatigue. I was told to try a better amp before looking for more speakers.What don't you like about the Topaz and Kenwood?
That's a fair point..The Moon does double power into 4 ohms, so that's good. But I can't tell you which of these would work best on your speakers.
- Is 40 watts per channel enough?
