and what about under max load? coz this thing only gets bigger
It does get a little bigger.
With the original power inductor I was getting 35 volts over shoot.
With the t106-2 inductor I get about 8 volts.
now you can put RC on each fet, that should reduce that a lot
But it is working fine now.
car with wrong AF mix works too, bet not as good
and you do want to sell, I would think you would want to make it better
More components means more cost and larger pcb.
I want to keep it as small and as cheap as possible.
I did try RC on the mosfets but it made little difference.
The oscillation is at the resonant frequency of the inductor so is at a high impedance and so shouldnt affect anything.
