Hi, I want to build any amplifier D or AB class amp. I found on ebay stereo kit IRS2092 "DIY Kit of L20D 200w-250W+200w-250W 8ohm IRS2092 IRFB4020PBF Class D" from user "besram-tech".
Anyone now is this good choice or have same amp? How sounds this chip?
I hope that this kit include all parts and heatsinks...
Possibly I'll build normal AB amp or order this kit, but this isn't easy decision...
PSU probably will base on 425VA 2x35V transformer and 4x4700uF capacitors (I think 2x47V after rectifier).
Absolutely. I'm using 4 L25D's and 2 L15D Pro's.
Here's a thread on these LJM boards. Lot's of good info there:
MY DESIGN L20D IRS2092+IRFI4020H 200W8R
hello,IRS2092 in only one channel,maybe you can try my thread
http://www.diyaudio.com/forums/class-d/236723-irs2053-irf6665-120w-3ch-class-d-would-you-like.html
Be careful. The only two authorized dealers/sellers of the LJM designed LxxD series of class D amp modules are 'along1986090' and 'zoe_tsang'. Beware of copy cats and clones that may use sub-standard components. I bought several of the assembled L25D modules (mono) from along1986090 and have been very happy with them. Full disclosure: I had one that failed. Unless you're a purist you'll warm up to the overall sonic characteristics of these class D.Hi, I want to build any amplifier D or AB class amp. I found on ebay stereo kit IRS2092 "DIY Kit of L20D 200w-250W+200w-250W 8ohm IRS2092 IRFB4020PBF Class D" from user "besram-tech".
I have an L20 amp and love it. I bought mine form Sure-Hifi. Nothing but the highest praise for this amp, I am running it on a 32v dc wall wart supply that barely make 20 va, and its phenomenal with that. I cant wait to feed it with a real power supply.
I bought a LM3886 with tube buffer from Zoe_tsang about 3 years ago, and have never assembled it. However, the power supply caps it it have already leaked. Mine may have been an isolated case, but just thought I'll put it up.
Cool.
Srinath.
Cool.
Srinath.
I have read about voltage pumping with this amp, which capacitance of supply filter for two unbridged board is required?
I have bought IR2153 to do PSU, but I'm afraid of about what I said (rising voltage with non btl board).
Cool.
Srinath.
Hi Srinath.
You're running an L20D off a single 32v PS? I didn't know that you could do that. I recall reading somewhere that you could change sodme resistors to allow the amplifier to power up at lower voltages but I wasn't aware that you could them run off a single supply.
Can you please explain how you did it? 🙂
Thanks!
My L20 is a TAS5630 based kit - I dunno what the L15, 20 and 25 are, I've seen L25 also based on a 5630 I think ... mine is rated to run off a single supply.
Cool.
Srinath.
Cool.
Srinath.
I am so sorry ... my bad. My L20 sits there un built.
I've confused the TAS5630 kit for the L20.
Cool.
Srinath.
Cool.
Srinath.
Already I have etched mine PCB, the most important thing of all DIY for me is learn sth and be glad.
I'm only looking for good inductor, rest of the components are easy to buy.
- Class D
- IRS2092 kit from ebay
