IRS2092 + IRFI4019 Questions
Hello,
I am considering buying a pair of LJM L-15D amps.I have a +/-55v supply. My speakers are 4 ohm. I read that the preferred power supply for 4 ohm speakers is +/-48v.
Will +/-55v present a problem with the IRS2092 + IRFI4019amps and a 4 ohm load?
Also, I use a tube preamp that I like very much. Is there an easy way to reduce the gain on the L-15D so I can continue to use the preamp?
Thank you
Thank you Grib.
I think that shows me just what I need to experiment with gain resistor values.
Do you think that +/- 55vdc into 4ohms would lead to any problems with bus pumping, (p26 of the manual you linked)? I usually do not drive my speakers with much power.
