Digging thru the archives revealed
that the Holton AV800, 1KW version
uses +110v/-110v rails, but under load,
the realistic values were +96v/-96v,
I think I read.
The VDSS rating is 200v. How accurate
do you think they ratings are ?
can we go let say 10% higher than
rated ? The reason I ask is... I
don't know if transistor manufactuers
under-engineer the parts slightly?
Randy Slone book of amplifier
construction said that a safety
factor of 2x would be good on
chosing transistors, ie, an
amplifier with +40v/-40v rails
would reguire a 160v transistor
(40v + 40v ) * 2 = 160v
Does anyone fear running the IRFP240
near 200v with +100v/-100v rails ?
I think I read.
My latest thinking is....
1. PCB layout 4" x 10" to accomodate
14 IRFP240 and 14 IRFP9240 per
channel, double what the AV800
design uses. Then, perhaps using
only +90v/-90v rails and not
+110v/-110v as shown in the
Holton 1kw amp (modified AV800).
2. Referencing this schematic, bottom of page;
http://www.aussieamplifiers.com/downloads/AV800.pdf
Someone suggested to reduce R28,
330 ohms, to perhaps increase the
drive capability of the VAS to
accomodate the extra paralleled
output stage transistors, but I'm
not an amplifier designer so I don't
know what needs to be done on
this particular design.
The power transistors array will
solder on the edge of the board,
14 across a 10" span of PCB,
one rail per side.
silly pic;
t = transistor
tttttttttttttt <-- IRFP240
|---pcb---|
tttttttttttttt <-- IRFP9240
This allows me to put 2 modules
on the one slab of heatsink
which will make the amplifier chassis
about 22" depth, perhaps 8" min.
height, and 17" width, a 4 channel
configuration, with option to bridge
to make it a dual mono.
What do you think ?
I like monster amps
If this works, half of my brain
wants to layout another PCB
that that is 4" x 16" to accomdate
40 transistors per channel, perhaps
to make it 1 ohm stable using
much lower rails.
Need help from the amp gurus
here just to get me in the right
direction.....
Right now I have access to professional PCB sofware and
I want to take advance of my situation and do some free layout......
Gonna build the AV800 prototype
next month, all my surplus electronic
stores here from my childhood has
gone under so I need to get parts
online from somewhere.
one rail per side.
silly pic;
t = transistor
|---pcb---|
What do you think ?
I like monster amps
much lower rails.
direction.....
thylantyr said:The VDSS rating is 200v. How accurate
rated ?
The X1000 runs the IRF240 and 9240's at 150V peak, and have never seen a failure due to voltage.
I suggest that if you want to get to or exceed 200V you individually check each part for leakage. Fortunately in this regard Mosfets are far superior to bipolars, so you can probably use room temperature measurements.
Do we fear this? No, we are fearless amplifier builders: The best kind.
Sweet!
Now the squirel cage in my head
is turning
Is Randy Slone correct in his
assessment that VDSS correlates
to BOTH rails or do you only consider
the single rail when trying to figure
out SOA of VDSS
Last question, should the source
resistor be increased in value
if you raise rails to Uberman
high voltage levels ?
ie, from lets say 0.22 ohms to
some higher value ?
Ok...thylanter...heres what I was told by Anthony. The av800/1kw amp can handle 10 device pairs (20 devices) per channel. He didn't mention 40. wow. Now, 40 sounds good to me, but I don't know how to do that. Once again, I think you should make the driver and output boards seperate. For instance, if you wanted to do monoblock amps w/ that design, and wanted to put the irfp240's on one heatsink and the 9240's on the other side, you'd need to make seperate output boards. Besides, I think it'd be cheaper...maybe..and monoblocks look cool. Again, if you can make more than one pair of boards, let me know and I'm in :-D email me at mattyo5@aol.com
Later!
-Matthew K. Olson
Later!
-Matthew K. Olson
Mattyo5 said:Ok...thylanter...heres what I was told by Anthony. The av800/1kw amp can handle 10 device pairs (20 devices) per channel. He didn't mention 40. wow. Now, 40 sounds good to me, but I don't know how to do that. Once again, I think you should make the driver and output boards seperate. For instance, if you wanted to do monoblock amps w/ that design, and wanted to put the irfp240's on one heatsink and the 9240's on the other side, you'd need to make seperate output boards. Besides, I think it'd be cheaper...maybe..and monoblocks look cool. Again, if you can make more than one pair of boards, let me know and I'm in :-D email me at mattyo5@aol.com
Later!
-Matthew K. Olson
My definition of mono block is
one PCB per side, channel 1
PCB left side heatsink, channel
2 PCB right side heatsink,
then bridge the two modules
for uberman power.
I think I read somewhere in the
archives, ? Holton? suggested
+70v/-70v rails for bridged.
Why settle for 90v swing single channel mono block when you can
get 140v swing with two channels,
more punishment for the speaker
... think bigger .....
more fireworks when something
goes wrong
It's all good, the transistors
cost $1.25 for n type. $1.75 for p type. Cheap firecrackers.......
Ok...so you are gonna use 4 "channels" then....2 channels bridged for 1 channel. I see. Ok, so use 10 pairs of devices per board, total 40 devices, bridge it...use lower voltage...maybe even +-50v ...shoot...I'm sure that'd be killer power and it'd work into 2 ohms then! (hopefully :-D ) that'd be like...600 watts into 8 ohms. you'd need a nice toroid to do that...sweet. Let everyone know when you finalize boards. Maybe others would be interested ...especially b/c Anthony is out of stock
-Matthew K. Olson
-Matthew K. Olson
Mattyo5 said:Ok...so you are gonna use 4 "channels" then....2 channels bridged for 1 channel. I see. Ok, so use 10 pairs of devices per board, total 40 devices, bridge it...use lower voltage...maybe even +-50v ...shoot...I'm sure that'd be killer power and it'd work into 2 ohms then! (hopefully :-D ) that'd be like...600 watts into 8 ohms. you'd need a nice toroid to do that...sweet. Let everyone know when you finalize boards. Maybe others would be interested ...especially b/c Anthony is out of stock
-Matthew K. Olson
Actually the plan is to <try> to
make one pcb with 28 output transistors per channel, 14 per rail, 2x more than AV800, 4 more transistors
per rail than AV-1KW.
Later, design another PCB which is
the same but longer, to allow 20
output transistor per rail, this would
be an experimental PCB... the
fireworks board - hehe
I want a modular channel design
to minimize the wiring rats nets
and keep all the parts close together..
The pcb will most likely mount to
a metal interface plate, either aluminum or copper.. The output
transistors would be directly mounted
on the interface plate with no
electrical isolator on the tab to
get best heat transfer from device
to hunk'o metal..... Then electrically
isolate/thermal grease the interface
plate to desired heatsink. So, both
pcb and interface plate will have
random mounting holes to make
mating easier to any heatsink.
So.... if you have a modular design,
then insert as many modules
as you want in any particular
chassis. If you want a 8 channel
amp, line up 4 modules per side,
that would be a chassis size of
17"W x 14"H x 22"D. This is
worse case scenario, I wouldn't
do this, I'd rather have 4 modules
in a small chassis, but you can
do it......
Realistically, the 4 channel chassis
would be the same size except the
height would be 7" - 8", more manageable.
Also, you don't have to solder
all 28 transistors to the pcb
for lower powered applications.
Suppose you want to build a 2 channel amplifier for the tweeters
only, well, you can populate just
a few transistors ... spread out ..
on the pcb and get a chassis with
12" depth.
Since I like fully active stereo systems
where each speaker gets it's own
amplifier channel, the modular design
allows you to build each amplifier
slightly different.
If you want to use the new high
xmax monster woofers that have
1 ohm - 2 ohm voice coils, then
build the bridged mono with all
transistors, scale down rails
and place both modules in a larger
chassis with more heatsink due to
1 - 2 ohm load
heheheh.......
The problem is.. I need to build
the AV800 next month to get
familiar with the design, I'm seeking
parts right now to make two, I
have two Holton designed AV800 pcb's...... won't fit 28 output transistors, but maybe I can build
an interface PCB later after I get
the generic one operational.. One
step at a time..
I have a bench test PS with +75v/-75v rails *and* +150v/-150v
rails...
My email is lordpk@pacbell.net
if you want to keep in touch
since you will have some experience
with AV800.. perhaps you can find
some kewl mods.........
The Randy Slone book has
some 'generic' protection circuits,
plus I have other schematics....
I've read archives here and some
people with rail fuses have had
big problems, one rail fuse blew,
the other did not, this caused big
DC offset --> blew up speakers...
For such a crazy project, I think I
need a rock solid protection circuit
designed into the PCB with beefy
output relay.. Speakers are very
expensive, would not be sweet
to have them go up in smoke
40 transistors per board is a LOT of $$$ to go up in smoke...for a fireworks board! Wow!! Be careful! Right now I'm putting together my symmetrical 400 watt boards, which are similar to the av800 w/o 3 gain stages I think. I wanted the av800 but Anthony didn't have the boards. Since the av800 can only handle 10 devices per rail according to Anthony...how do you plan on beefing this up to handle 20 per rail? Thanks!
-Matthew K. Olson
-Matthew K. Olson
Mattyo5 said:40 transistors per board is a LOT of $$$ to go up in smoke...for a fireworks board! Wow!! Be careful! Right now I'm putting together my symmetrical 400 watt boards, which are similar to the av800 w/o 3 gain stages I think. I wanted the av800 but Anthony didn't have the boards. Since the av800 can only handle 10 devices per rail according to Anthony...how do you plan on beefing this up to handle 20 per rail? Thanks!
-Matthew K. Olson
Nelson said;
Post #8
The most outputs I have used in a commercial
product is 80. per channel.
If you provide enough drive current to them, there is
not much of a limit to how many you can parallel.
muuuhahahahahaha.....
I asked the question about paralleling
earlier.........
http://www.diyaudio.com/forums/showthread.php?threadid=5288&highlight=mosfet
Note the date
I've been trying to finance and juggle
both my projects, the crazy speaker
project and the crazy amplifier
project, which causes delays for
both.
Also, keep in mind.. if the design
can't be modded to handle 40
per channel, the PCB is still good!
Just solder a transistor on every
other solder pad......
Considering the cost of exotic
home amplifiers, doing a crazy
experiment is cheap.........
The crazy speaker project is
11 drivers per channel..... yikes......
Four 8" midranges, Four 5"x8" planar
tweeters, three Lambda Apollo TD15H
per channel.............
Are you gonna have these PCB's professionally done or are you gonna do them yourself at home? B/c Anthony charges $50 per board...so if you could find a way to charge half, mod the board for more outputs...that'd be pretty cool. I think there'd certainly be interest here on the board for that. Start a wiki or group buy or something...but ya gotta prototype one to make sure that adding the extra output transistors is possible...so as no to waste money on the extra board space for more transistors. So prototype one board...get it working, and then get a group buy goin! :-D
Hopefully I'll get my 400 watters built as soon as possible and let everyone know how they sound. I'm makin my own output boards w/ copper foil :-D later!
-Matthew K. Olson
-Matthew K. Olson
Both
My line of work is actually
professional pcb layout, going
to "borrow" the software
I kinda got herded into this line
of work ... at work .... The software
we use cost $50k per seat, the board
sim software cost $20k....
My goal with pcb layout won't
be cost, I'm going for quality
first, hence the 4 layer circuit
board (expensive). Gonna try
to design to accomodate for
power/ground gold plated buss bars
mounted on the pcb similar to old
school phoenix gold car amplifiers,
looks perty...... extreme overkill ...
Once done, I can easy mod the
PCB design for 2 layer pcb if you
want. Once you have the gerber
files, anyone can build boards,
perhaps even etching your own.
Someone posted a method to
print gerbers on a laser printer
using transparencies...... then
exposing the pcb with this.. viola'
So far, the cheapest vendor I can
find for IRFP240 is;
http://www1.future-active.com/Comergent/en/US/adirect/future
$1.125 ea. (sold in a tubes of 25)
9240 cost $1.76 ea.
These are International Rectifier
parts, I also see many vendors
selling Fairchild equivalents for a buck,
but I don't know which transistor
manufacturer is better, assuming
IR is better
Have you found heatsinks for your
project ?
Both
9240 cost $1.76 ea.
IR is better
project ?
GREAT link. Thats 1/2 the price of digikey!! I'll definitely be ordering from them from now on for the irfp's!!! Thanks!!
Well..once again, when you get your design done...let me know. A 2 layer board would be much easier of course...so maybe we can get a group buy together! Would be GREAT! Later ...thanks!
-Matthew K. Olson
-Matthew K. Olson
- IRFP240 Questions
