Hello,
I can get the IRFP240-IR (the number of the distributor) accoording to them it is a:
HEXFET-20A-200V-N-KANAL-TO3P-0.18 OHM
however... does a IRF-P-240 exist in the TO3P case or is the IRF-P-240 only available in TO247?
So, is this an error in their database that they copied the description of the IRF240 when the entered the IRF-P-240?
Thanks,
Edwin
Thanks,
Edwin
Nelson Pass said:These are pretty much the same case, if not identical.
I wouldn't worry about it.
Thanks,
the reason I asked about it, is not that I worry about difference in quality, but I like to get the TO-247 for reasons that they are far more easy to fix to a heatsink. Less holes to drill, no isolation to worry about, and the wires are all on the same side of the heatsink
So my question more or less comes down to: If I order IRF-P-240 fets, will I automaticly get TO-247 or were/are there IRF-P-240 within a TO3 case or are these in the TO3 case called IRF-240 ???
Thanks,
Edwin
Package
IRFP 240 N-CH 200V 20A 150W 0,18R TO247
http://www.irf.com/package/pkhexfet.html
http://www.ic.nec.co.jp/discrete/japanese/pkg/to3p.html
Just to clarify:
TO-3 is a metal case.
TO3P stands for TO-3 Plastic, and is a plastic flatpack which looks (and performs) very similar to a TO-247.
What some manufacturers call a "TO-3P" can vary somewhat - some use the term interchangably with TO-247, and for others there are slight differences between the two, but it's always a flat plastic package with a single isolated mounting hole, if I'm not mistaken.
ThingyNess said:Just to clarify:
Thank you very very much,
very confusing to use TO-3 for 'old-style' metal case, and TO3P for a TO-220 plastic look-a-like case.
Ok, I am going to buy these tomorrow! By the way, they are only $1 each
Edwin
- IRFP240-IR = to3 or to247?
