Hi Guys,
I have a line on some freebie parts...which is always good, and am wondering if the IRFP140 would be okay in the Aleph J, I am thinking it will be fine as the main difference is in voltage rating, Ciss is about the same @1400pF. Second, would this pair work in the F5T V2 or V3 if I keep the rails below 50VDC? I would like to build the V3 with the 8 outputs per channel. I know the 240/9240 are available, but the Fairchild parts are EOL and when free stuff comes along, it's nice to be able to use 'em.
Your thoughts?
Cheers
Paul
Your thoughts?
Cheers
Paul
Perfectly fine if the rails don't exceed 100V.
Last time I looked they have a slightly greater transconductance, but not
enough to get excited about.
Ahhh, Nelson,
Thank you so much for stopping in and letting us know we have options. Much appreciated. I have many torroids from past projects, mostly the same dual 17VAC @ 6A and 24 VAC @ 8A windings, tag says 200 and 319 watts, so I can parallel or series them as required for the Aleph J or F5T V3. Should see about +/- 30VDC for the Aleph J and either +/- 35 or 60VDC for the F5T. Here is the thread I started, trying to decide what to build next, Aleph J, F5T etc.
http://www.diyaudio.com/forums/pass...-15-years-passt-projects-amp-build-first.html
So on another note, I am still about to rebuild the Stasis II, which I have had apart for over a year now. Finally have all the new 48 outputs and drivers etc. See my other thread...
http://www.diyaudio.com/forums/pass-labs/198286-threshold-stasis-ii-help-needed-please.html
Also sometime this fall/winter, I need to build a preamp based on one of your designs, be it a BA-3 line stage or ???
I must restrict myself to only 3 projects at a time. 😀
Thanks again!
Cheers
Paul
Thanks again!
Cheers
Paul
My four channel F4 uses IRFP240/IRFP9140 pairs in two channels.
They are fine.
I'm raised PSU voltages to +/- 35V without hassle.
If we don't mind the exceeding heat.
Best regards,
Gyuri
They are fine.
Best regards,
Gyuri
Gyuri has chosen the mixed pair which are recommended as better complementary pairs.My four channel F4 uses IRFP240/IRFP9140 pairs in two channels.
Yes, I read it somewhere earlier.
And datasheets also show this to me.
As much as possible with my runted brain as I can judge it.
I must have to say, I don't experienced any differences between 240/9240 and 240/9140 pairs.
Regards,
Gyuri
Regards,
Gyuri
Hmmm,
I managed to score a bunch of FET's at a good price.
I have IFRP9240 and IRFP340.
http://www.irf.com/product-info/datasheets/data/irfp9240.pdf
http://www.irf.com/product-info/datasheets/data/irfp340.pdf
They look to be fairly complementary, would anyone be able to take a look at confirm (or deny!) that they might be suitable for an aleph-J or F5.
I've only got half an idea of what I'm looking at... 😕
Thanks if you can help,
Mark
Mark
So is the front end is the same at 35 volts ? That is about 50 watts per channel in to 8 ohm class A is it not ?My four channel F4 uses IRFP240/IRFP9140 pairs in two channels.
They are fine.
Best regards,
Gyuri
Yes. I'm a fearless burning amplifier builder.
I'm worried about the 2SJ74/2SJ108 JFETs because of 25V GDS.
I don't have countless pieces of them.
But they are survive.
I must to say, I can't perform a comprehensive test with this configuration, depending lack of a proper preamp. It wasn't a really dynamic condition test.
So, perhaps these delicious devices don't survive, if I can put to them a full voltage swing.
I can say, I never ever burned any of Pass designs.
Despite of that I always push the limits.
I think, IFRP9240 and IRFP340 will be fine.
But I'm not an expert.
On the youtube video of burning anp thing in 2010 Papa states that the absolute max on the 2sj74 is 43 not 25 volts so I think you are well with in the real limits on it as well as the for the 170 . For that mater neither an I the expert on this.Yes. I'm a fearless burning amplifier builder.
Yeah I think so..
They are maybe higher voltage but lower current than IRFP140?
I guess as long as I don't push the bias and watch the temps they should be ok.
Anyone else know for sure?
Mark
- IRFP140 and IRFP9140...anyone tried them in Aleph J or F5T?
