Irfp044?
I seem to recall using the N's recently, and I didn't notice
any difficulties. For the supply regulator and the current
source it is not nearly as important, and I often use
IRFP240's there because I have a warehouse full of them.
:smash:
I only have a stock of 044's, but if we go by the data sheets,
it appears that the 044N has lower capacitance and wattage.
Probably has a smaller die.
This doesn't tell the whole story, but there is no reason to
think they won't work fine, maybe better.
If you parallel them, match the Vgs at the idle current, and
use Source resistance to equalize current sharing.
