IR Receiver - 3.5mm jack for Home theater Processor
Is it a stereo or mono jack on the Rotel? If it is stereo, Xantech has a model with a 3.5mm stereo plug, tip=IR, ring=GND, sleeve=+12V. I would suggest checking if the Rotel's jack has +12V across the sleeve and ring. If the sleeve and ring are shorted (i.e. a mono jack), then it is most likely an IR input jack, usually tip=IR, sleeve=GND. If this is the case, a connecting block will be needed to give power to the IR sensor.
- Richard
No power, looks like I need a connecting block.
I have a salvaged 3pin IR receiver from an old VCR.
Any tips on what I need to supply power to get this working?
FWIW there is an available 12v trigger on the processor.
