Does any one know,
Of an Ipod dock with a Wired digital phono out that will connect to an existing DAC..NB not optical out?
M. Gregg
M. Gregg
OK found one..
I must have looked in the wrong places..there are quite a few..eg pure I-20 etc..
M. Gregg
M. Gregg
Compatability,
Can be an issue with the Pure dock....🙁
http://www.pure.com/products/ipod-compatibility/
The search goes on...
M. Gregg
M. Gregg
Onkyo | ND-S1
has SPDIF coax and optical outputs and you can play from your PC (USB) -> Dock -> DAC too.
Compatability,
iPod/iPhone/iPad Compatibility | Pure
M. Gregg
I have a couple of the Pure i20 docks, at my work computer desk and at the workshop bench. AFAIC they're stupid good value - includes Toslink and copper coaxial digital out, analog from the fairly decent onboard DAC, as well as composite & mini component/S video (neither of the latter 2 used in my case)
IINM, Apple's not currently licensing use of the Lightning mini connector found on iPhone5 and latest iPads etc to accessory makers, so adopters of the latest gen are stuck with Lightning to 30 pin adapter cables for use with existing docks. I'd avoid the stubby adapter myself
I think the problem with the Pure is,
I have a 5th gen classic 80..that I like and its not compatible with the pure i20..others in the family have the new versions...🙁..LOL
Is the ND-S1 compatible with the 5th gen classic?
M. Gregg
M. Gregg
Thank's for the help..
I will look closer at the spec's...🙂
I have a pure on order..LOL..well its worth a try...even for the other Ipods.
M. Gregg
M. Gregg
I don´t own a 5th gen to test it with, I use it with a 6th gen classic,
a 4th gen and a Nano3G I tried worked too.
Hello,
If anyone is still active on this thread I have a couple of questions.
Just received a new I-20 and can't seem to get working. The very brief operating manual says something like this...plug it in and switch it on. Then there is a separate section that addresses how to use the remote. "Turn the switch on" what switch?
The unit doesn't respond to the remote either. Tried a new battery for the remote...no luck.
I hope I'm missing something simple otherwise it must be a defective unit?
Thoughts please.
Anyone attempted to return a defective unit?
Lastly, once I get this unit up and running can I run it directly to the amp without a preamp?
Thanks for any help!
Kindest,
Marko
Thoughts please.
Kindest,
Marko
Hi, I'm a bit late in answering and this may seem like a dumb question but did you connect it to the power source? There isn't an on and off switch basically it activates when you activate/use your ipod. For home you connect it to an AC sourse (outlet) but in your car you'd have to find and connect to a 7.5 DC Power source.
This thing sounds really good when connected to digital because it bypasses Apple's DAC and uses it's own, better, DAC. Still, you are limited to 24 bit/44 kHz files. You aint getting 96 or 192 kHz out of it like the box says, unless someone's found a way.
Also, when I hooked mine up to my home theater, only the Coaxial (digital) and RCA (analogue) worked with my amp. The Toslink (optical) didn't work however that could be my amps issue.
- Digital Source
- Ipod dock
