I'm curious. Have you built this circuit to see if it actually performs as a "low distortion 20 dB preamp?"
No, before building anything I thoroughly investigate the circuit via sims. Extremes get much attention and I discovered the issue increasing the screen grid resistor to 22 meg. That's not optimal because the DC value at the cathode follower should be ~0.5 Ub. My suspicion started when lowering Ub of the circuit below to 200V, to accommodate Vfk of the 6F12P. At 300v, this THD sim and below, the circuit.
