Hi Mastertech,
what means "NEZ" ?
First I see this topology in "elektrotechnik, oktober 1983" (Dr. Harms, University Hannover) used for a 25 VA poweramp for +/-350V outputvoltage.
It is a simple circuit to generate high voltages with a minimum of highvoltage n-transitors (or fets).
From there i tried it some years later (as a A/B-amp for +/- 500V) and i find it suffers at high frequencys on a strong asymmetry which stem from the capacitys of the bottom power/control-transistor/fet.
May be for a CLASS-A SPECIALIST and class-a biased and for smaller voltages it is useful!:
So its good to use high ft-devices.
You can supply the base of the top-darlington from a current-source or bootstrap it.
Because its a transconductance-amp you need strong feedback to get a lo-impedance output so i think you had to add a 2. gainstage. (i used a op-amp)
To hold the voltage before the outputcap stable you need from there also a dc-feedback-path.
Good luck.
Heinz!
what means "NEZ" ?
Good luck.
Heinz!
powerbecker said:what means "NEZ" ?
Not Exactly Zen?
Just a guess.
Oh! Duh. It's Zen spelled backward.
se
Steve Eddy said:
Not Exactly Zen?
Just a guess.
se
Ha, thank you!
I search for Zen and find it (NP)!
Indeed, the Zen looks very similar, but he has a CONSTANT-currentsource in the top, the Nez-top-currentsource is steering by the bottom-currentsource!
Heinz!
powerbecker said:Indeed, the Zen looks very similar, but he has a CONSTANT-currentsource in the top, the Nez-top-currentsource is steering by the bottom-currentsource!
Heinz!
the top of the Nez is a constant current source, loading the bottom common emitter for gain.
Hi tlf9999
this is true for Zen. Btw the bottom common emitter works also as a currentsource but not as a constant one.
The Nez consists of 2 currentsources like the Zen but in contrast to Zen none of them is constant. So you can get better efficiency.
Heinz!
Hi guys wow the view count is heating up
micheal yes you could add resistors to darlington network if
the circuit is made up from regular transistors, thanks for
your kind suggestion, btw are you German Engineer we get
a lot of them in this thread thats why im asking
thank you all guys i plan to use all of your suggestions in future
versions of Nez
regards
George
versions of Nez
regards
George
- Introducing NEZ
