Intro
Greetings from Malaysia.
Having visited this site for the past few years, I've decided to reg. Projects that i have completed are 1) Aleph 5. Pretty hot amps. 2) Balance line for the above. Next in line is to upgrade A5 to Aleph X . Is there any left over GB pcbs around , i would like to get my hands on . Do let me know.
Finally i would like to say a BIG THANK YOU to the (ONE AND ONLY) MR NELSON PASS. You make the world turn upside down with all your ideas.
ETL
Photos of past projects
Hello Cal,
Re: Photos of past projects.
As the projects are completed a few years back . I'm only able to take some pictures of the system that is in use now.
Thorens Td 295 Mk 3 c/w Tp41 T/arms & Ortofon /OMB 10e
Diy Phono stage using Op amps BB OPA 2134 This sounds better than the original Rotel Phono Equaliser. (The Small Silver casing in middle.)
The Power supply section for the Balance line. Note . I use unbalance in and balance out.
The pre section with Volume & Input selector.
The internal pic of the Balance line. Note that i use p2p wiring and its look like a bird nest
Both the power supply pic & control pic.
The Monster power amp at the bottom of the whole system size 19.5 " wide 20" deep 12.5" high.
This is how it looks . the speaker in use is B&O 4 ways and its power hungry. I have a pair of caliper Sig which i would like to use very much. THats for all now. Hope you like it
ETL.
