Intro - I've thrown myself in the deep end
Afternoon All.
I've been building a set of active 3 way monitors and I've finally got them "finished".
I'm use the term "finished" because the port length needs to be tuned and the dsp's setup.
Maybe assembled would be more accurate.
They're getting sent off to a guru to be set up properly, but I was keen to have a crack at sorting what I can prior to sending them off.
The crossovers are set as below:
With all the IIR / FIR / Gain adjustment per channel set to default/off, I get the following:
I've been digging around for guides to set this up, but I keep coming across info for setting a room up, rather than a speaker.
I'm hopeful someone can point me in the right direction.
Cheers
Ben
I'm interested in your comment as I don't currently have a method to measure the resonant frequency of the enclosure. I was thinking there would be an obvious spike in the frequency response, that could adjust by changing the port length, but nothing sticks out.
I'm down in Christchurch....
It always amazes me how many closet audiophiles are kicking around the place.
We've got Plinius and Theophany based in the region here.
Some VERY smart cookies around, who are playing in this space.
