I have contactes interteknik, but no response
https://www.intertechnik.com/Shop/Amplifier-electronics-streaming/_Mini-D-5050Amp_1768,en,7051,157012
Anyone know this amp - chip, is it real 50 watt or 10% distortion etc
Technical specifications:
Power at 1% distortion: 50 Watt / 8ohm per channel
Signal voltage ratio:> 100dB
Input voltage with jumper: 0.6V
Input voltage without jumper: 1.2V
Frequency range 20Hz - 20kHz +/- 1.5dB
Channel crosstalk 80dB at 1kHz
Dimensions 105 (L) x 85 (W) x 41 (H) mm
PSU 90-260 volts 50 / 60Hz
Source: https://www.intertechnik.de/Shop/Ve...Streaming/_Mini-D-5050Amp_1768,de,7051,157034
I found out some more. It's a Luxus Audio Wagner, and seems to be from Italy. Theres some info on Italian hifi sites, but my Italian is not so good.
WAGNER 2 channel Amplifier high quality DIY 50 watt Class D already mounted + power supply LUXUS AUDIO
I came across Formosa again (have been looking at their bigger modules before). It seems that the Luxus Audio Wagner is made by Formosa
Stereo digital power amplifier - FORMOSA AUDIOMATE LTD.
