Interstage/Input Transformer
Hey Anyone,
In this schematic is an interstage transformer. Could I use that as a balanced input. To drive four 6P15p's? And if I could would it be better to use each secondary tap to drive one tube? Or would you run them in parallel to drive two banks of outputs. Or would it be better to use the schematic the way it is?
  • M0010294.pdf
