I need the help of the collected wisdom of the fullrange guru's.
Is there an easy way to interpret the given T/S values of speakers and to then know what kind of enclosure that these would then suit?
I appreciate that the actual design of said enclosure is another matter, but I wonder if there is a formula that says, if you have T/S parameters in this range, then this is the type of enclosure that would suit that speaker driver.
I hope that you can help.
