I'm looking at the Mini Dissipante 3U (250mm) and the Slimline 2U (280mm alum) for two different projects and I'm trying to find information about the size of the internal brackets. From the photos I've seen, these look like they are about 10mm x 10mm angle brackets along the top and bottom and up a little on the back and front panels. Is there a drawing available anywhere that shows the exact dimensions?
Thanks.
Thanks.
Hello Jay,
You can download the drawings of our chassis from here Hi-Fi 2000 contenitori per l'elettronica, case modding HTPC, Galaxy, rack, DIYaudio, computer cases, front panel express, knobs,milled Handles, milled fronts, hi-end,
Thanks for the link. It looks like the back panel bolts directly to the side panels for the Slimline 2U. But I couldn't tell how the base is connected. Are there any internal brackets that would prevent connectors mounted to the back panel from using the full 80mm internal height or 415mm internal width?
Thanks.
Thanks.
Once the inner pierced base is mounted, the inner useful height is reduced of about 4-5mm. In the Slim Line chassis the base is mounted on the "rails" of the side panels, you can find a picture here http://www.modu.it/base_interna.jpg
Thanks. This is helpful. I assume what you mean by "mounted on the rails" is that the bottom plate screws onto the bottom of the side panels and no additional internal brackets are required to mount the bottom plate.
I'm also assuming that the inner pierced base is optional.
It looks like it is only the front plate that requires internal brackets if I decide not to use the inner pierced plate. Is this correct?
Thank you.
Thank you.
That's correct, the inner baseplate is optional and it is not required to fully mount the chassis.
If you plan to buy a chassis with a 10mm front panel you'll also find in the package the internal brackets to fix it to the side panels, these don't need to be purchased separately
- The diyAudio Store
- Internal chassis brackets
