I plan to interface your MiniDSP kit with a Presonus Firestudio Project, which has +4 dBu balanced outputs on 1/4" TRS jacks.
* Should I use 'RevA' or 'RevB' of your MiniDSP kit
* Should I worry about anything while interfacing my +4 dBu output with your -10 dBV input?
Thanks,
Jai Shankar.
Thanks,
Jai Shankar.
Jai,
A couple of points to remember:
1) If you're balanced out, you'll need a balanced to un-balanced interface between your Presonus and the miniDSP (unbalanced inputs)
2) If the output is indeed +4dBu (1.2Vrms), then RevB will be a better choice.
Hope this makes sense
