Well -- good thing I never encoded anything (A to D) with my PCM2702 for saving in my music library.
Playback sure sounds damn good though -- as good or better than CD, but then maybe I'm missing something -- including a pair of golden ears?
I'll have to bone up on all of it.
Thanks for the feedback.
And also -- in case someone can respond, what is the deal with the SPDIF output on a PCM27XX chip?
Why would you want to convert from USB to SPDIF, only to have to do even more conversion getting it back to analog?
Wouldn't you want to get SPDIF straight from the PC on a sound card?
Hi jmar,
PCM2704 is an easy solution to add an USB input to converters having multiple S/PDIF inputs. Just put PCM2704 S/PDIF output on an existing input.Why would you want to convert from USB to SPDIF, only to have to do even more conversion getting it back to analog?
Many sound cards don't include S/PDIF output.Wouldn't you want to get SPDIF straight from the PC on a sound card?
I was asking also in reference to USB being an "inferior" transfer as stated earlier in the post.
Isn't SPDIF just a straight synchronous digital transfer (I can't remember) -- no packets or all this talk about jitter etc? (If you send a WAV file or MP3 or any type of encoding, does SPDIF maintain it's integrity?)
If it's USB that's feeding an SPDIF output, then you still have USB and it's "flaws", don't you?
Sorry -- but I have hard time getting my head around this.
Hi jmar,
S/PDIF provide continuous stream at 64xFs (Sampling frequency). So a PLL can lock onto the frequency.Isn't SPDIF just a straight synchronous digital transfer (I can't remember) -- no packets or all this talk about jitter etc?
The S/PDIF stream is normalized, you could not send anything.(If you send a WAV file or MP3 or any type of encoding, does SPDIF maintain it's integrity?)
Not exactly, the stream must be continuous and match with sampling frequency. USB send discontinuous packet matching with sampling frequency too.If it's USB that's feeding an SPDIF output, then you still have USB and it's "flaws", don't you?
Firewire protocol
Hi planet10,
Perhaps there is an existing Diyaudio thread speaking about this?
Hi planet10,
I don't know Firewire normalization. Is there a dialog protocol between emitter and receiver? Does the receiver ask data when its buffer is empty, or is there a continuous data stream?Firewire was designed to transport media.
Well - let me ask this then.
From my hard drive full of uncompressed WAV files to my speakers, start with Firewire for my DAC?
For the ultimate in fidelity?
Funny thing is -- from the very beginning, I liked the idea of these PCM27XX chips because the took the analog audio FAR away from the PC. They do sound good but I'm always interested in anything better.
Didn't even think about USB with respect to primo audio. (meant for printers -- lol).
I'll have to look into it but I would imagine there are stand alone boxes with firewire input and analog RCA outs? -- and THAT is THEE way to go?
Firewire out of the PC into the DAC. Then the DAC does its job & gives you analog.
In the low end pro gear is where to go. In the extreme hi-end, consumer breakout from pro gear like Wiess, DAD (Digital Audio Denmark), and of course dCS. I can't play in that area getting an Edirol FA-66 and wishing i could afford a Metric Halo.
dave
Firewire = IEEE1384. Google it.
dave
Banned
Joined 2002
dave
Constructive discussion
Hi planet10,
The problem is more complex. You can find another thread about digital link between PC and DAC here : Pc -> Dac, How ? #1
Firewire, dead or alive? Pc -> Dac, How ? #129
Planet10, it might be useful to have constructive discussion and not speaking about your personal point of view.
Hi planet10,
IEEE1394, thanks Father Planet10Firewire = IEEE1384. Google it.
And USB do the same thingFirewire out of the PC into the DAC. Then the DAC does its job & gives you analog.
I've offered what i can. My experience is pro Firewire. And the stuff pushing the edges is all Firewire.
dave
I have a PCM2702 and a couple of opamps I use as a preamp -- I love it.
Great. The internal dac of the 2702 is exceptional.
But is it because Firewire is fundamentally better suited for sound transmission or is it just a question of implementation. Per example have you been able to compare async USB/I2S to Firewire/I2S? From what i know Firewire is not very diy friendly. For one you need drivers.
Firewire is specifically designed for media so has an underlying architectural advantage.
Firewire is not as diy friendly because their is no single chip solution like the 270x chips.... but then once you want to go past the limitations of the 16/48 of the TI chip USB is actually less diy friendly because you have to write some pretty tricky software.
Firewire works on my computer without drivers.
dave
- Digital Source
- Interface : USB or NOT
