Just back home from a business trip and found the board at home.
Really well done as usual
Thanks and Regards,
Enrico
Thanks and Regards,
Enrico
If you (all) wish to receive the documentation, you need to send me your email address.
For example by PM.
Patrick
For example by PM.
Patrick
Received docs. One question, there are 78xx, 79xx, 78lxx and 79lxx ICs called for. I am guessing a linear regulator either 7815 or 7824 and 7915 or 7924 depending on desired output. Brand not critical.
Tnx
David
Tnx
David
One more, regarding best fuse value. I have the two SHPP boards to go with the mother board.
Size of fuse?
Size of fuse?
As in any of our heapdone amp projects, you can use any regulators for the main amp which are 78xx / 79xx pin-compatible (TO220).
Almost all of our projects are supplied with discrete regulators of different sorts.
Voltage to suit that particular amp.
The 78Lxx / 79Lxx are for the SHPP.
We recommend same voltage as the main amp.
Fuse depends on power consumption.
Suppose you use a +/-24V UTHAiM with 22Vrms Talema.
And let's say you want to bias at 180mA.
And mains is 115Vac
Total power = 2 x 2 x 22 x 1.414 x0.18 = 23W.
Mains current = 0.2A.
I would then use a fuse of say 0.4A slow blow.
Patrick
And mains is 115Vac
Patrick
Patrick, forgot to tell you the board arrived the other day, very nice indeed. I like that the regs can be plugged directly to the PCB.
Is there a component suggestion for the aux PSU's? I haven't checked the other threads for this sorry
Please send me your email address so that I can send you the documents.
Also please confirm if you still want to join the F5X Power Amp GB :
Interest for Final GB for F5X Power Amp
Thanks,
Patrick
Thanks,
Patrick
- Group Buys
- Interest for XEN Headphone Amplifier Motherboard
