I recently inherited a pair of tower speakers, Interdyn with SEAS drivers, each cabinet having dual sets of binding posts strapped with a jumper. Wired as such, I can hear the 3 drivers in each cabinet working.
BUT: when I disconnect the jumpers, I measure zero (0) DCR across the upper pair of terminals (highs), while measuring about 4 ohms across the other terminal pair (lows).
That said, when I connect a solid-state amplifier to the zero-DCR pair, high frequencies indeed come through the tweeter. And lows are delivered to the woofer through the other terminal pair, as expected.
My question is: is it safe to connect a valve amplifier to the zero-DCR pair? I don't want to present my pride and joy with a zero-ohm speaker load!
Mind-boggling, if you ask me. There's a massive crossover network inside each cabinet, comprising transformers and such... yikes!
Any clues as to an explanation would be appreciated.
That may be a step-down autotransformer on the tweeter. It should be perfectly safe for a tube amplifier.
The tweeter Xover will have a series cap as an HPF, so you won't be able to measure any DC
He says that he does measure a low resistance on the tweeter input, so the capacitor must be after the autotransformer.
