I am putting in two twelve inch Pioneer IMPPs (TS-W33C) into a a 1998 cavalier 2 dr coupe. Does anyone have any idea on the measurements for building a box for them? Like what thickness of mdf board should I use and what should the dimensions of the box be?
Hi
From what I found @ google it is recommended to run one woofer in a closed box with 1.5 cu ft.
What you will need to do is use 3/4 inch mdf, liquid nails and a bunch of screws. If these are new subs look the paper work for the cubic foot requirements per sub. If you do not have the infomation get ahold of the maker, you cant do anything without that info. You have to decide if you want to use a sealed box or a ported box. These links will help http://www.termpro.com/articles/buildbox.html http://www.ajquick.com/cars/guides/sub_wiring.php#d1 http://www.the12volt.com/caraudio/boxcalcs.asp
Good lusk and measure twice and cut once
