Hey guys,
I have a piece of recording equipment that only accepts balanced inputs, and I would like to pull input from the Insert plugs on a board that will also be used for live mixing. My question is: is there a good/accepted way for doing this? Can I simply connect the tip and ring on the soundboard side to the tip on the recorder side, and connect the soundboard's ground to the recorder's ring?
the tip->ring connect is so that the audio is passed back in so live sound is still heard.
Now, this seems too crazy to work, and if it won't I'd appreciate an explanation of why not(if you have time!).
Thanks.,
-Adam
Thanks.,
-Adam
This will almost always work just fine. Maybe bring the recorder's ring connection back to the board to ground there * - no biggie but usually good practice.
Sorry for all the qualifying "maybes" but, as you know, there's a lot of strange stuff out there in pro-sound land, and no single standard. Anyway, easy and safe to try.
All good fortune,
Chris
* rereading, it looks like that was yout intention all along!
All good fortune,
Chris
This worked great! I recorded two tracks to test. I recorded from the insert using my converter cable and I ran the input out of an AUX send with everything at unity. I flipped the phase of one of the channels and still heard a little bit of sound and it turns out, the insert track was slightly louder than the AUX track. I'm not sure what exactly caused this because I did my best to leave everything at unity. The IN/OUT jumper has low enough resistance that it shouldn't be the problem. I guess I'll just count this one as bad board electronics.
Long story short:
It works!
Thanks,
-Adam
Long story short:
It works!
Thanks,
-Adam
