Hello there
i have two of the above amps and the inputs on the left hand side on both have stopped working (both phono & 1/4 inch jack) im getting no sound at all from either one , the sound is perfect in the right hand side
On the front the led light isnt working either (to indicate sound)
My question is what could be wrong
regards in advance
stuart
regards in advance
stuart
go to post #2 about
http://www.diyaudio.com/forums/soli...blown-output-circuit-diagram.html#post2506917
for schemas.
Who knows the exactly manufacturer in China ??
for schemas.
Whip off the back and look for loose connections or bad solder joints on the input board.
Must be a common fault with them, I have one that intermittently works on one channel.
