Input Stage for Digital Amplifier
Hi
I am currently building the input stage for a Class-D sigma-delta modulator amp in an FPGA (If this rings a bell, I am Gretzteam's partner in this crazy adventure!). Anyways, the CS8414 Digital Audio Receiver from Cirrus Logic seems seems like a logical 😉 choice. I have read a lot on the AES-S/PDIF protocol and decide it would be wiser to use this chip instead of implementing it on the FPGA. Anyone has experience with that chip?
From what I have seen in the datasheet(http://www.cirrus.com/en/pubs/proDatasheet/8413-4.pdf), I should select Mode 0, which outputs the clocks (FSYNC and SCK) and 16 bit interleaved left-right audio data. Is this right? I also plan on hardwiring the SEL pin to ground to get the error and frequency reporting option (although I do not plan to really use it as our input will only be from a cd player).
I want the simplest implementation possible. In other words: Should I (Can I?) leave the User Bit pin and all Channel Status pins (Output, block start, channel select) floating and not bother with them. I know about the SCMS stuff but do I need to deal with it?
Once done, I need a serial to parrallel converter (FPGA implemented) From what I see, there is no start/stop bit. Is FSYNC good enough to guide me through left/right channel switching. What about reseting? How long (clock cycles) should I reset the chip on a power-up?
Any ideas and/or comments would be greatly appreciated!
SpeedWheel
