Looks more like a start from scratch using the same basic set of drivers.
dave
Not sure, but I thought it was built around the Thor design. I can't find the link where he discusses it, so I may be wrong.
It is a good project if you want to know about how things go wrong.
Despite Joe being considered a master speaker design and having literaly written the book on testing, he blew the design of the TL and compounded it by making a stupid measuring mistake.
http://www.diyaudio.com/forums/multi-way/64799-clarity-seas-thor-kit.html
This is a design i would never personally consider, unless it was part of an article to support the thesis of the above thread,
It breaks 2 guidlines that i hold dear: 1/ it puts an XO right where the ear is most sensitive, and 2/ the centre-to-centre distance of the drivers is greater than 1/4 wavelength at the XO point.
It is also a lot of money to spend on a 1st effort.
I'd suggest getting a pair of these: You can learn a lot.
The Madisound Speaker Store (also available with copper cones)
They may well save you of much of the "conventional" wisdom, and even if not, make a 1st class midrange.
dave
Thanks! See, this is invaluable stuff. I was blown away when I found this joint. With respect to the THORs, I guess I fell for the old Appeal to Authority logical fallacy.
D' Appolito designed these so they must be good.
My first thought of this place was: "Holy cow, this is a gold mine!"
As I see it, my being an engineer gives me only the advantage of having a head start on the general physics. It's the experience and how to apply those tools that I lack, and hopefully I can get the "how to" from reading the members thoughts here and the experience from just plain trying.
Edison was once asked how frustrating it felt to attempt to invent the incandescent light a 1000 times and fail.
His answer was: "I didn't fail! I found a thousand ways on how NOT to design an incandescent light".
Maybe with a little help I won't have to attempt this a thousand times.
The "theory" of small signal TS parameters bass analysis is well known and
built into many simulation programs, e.g. Basta! goes into the the details :
Basta! technical documentation
Large signal analysis is a completely different kettle of fish and Home is
probably the best resource available to learn about the ins and outs of this.
FWIW designing the bass end of speakers hardly ever involves
the use of anechoic chambers, they are inaccurate in the bass.
rgds, sreten.
If the problem between small and large signal analysis is analogous to the use of S-parameters in large signal RF amplifier design then I am assuming that you are implying that the TS parameters provide for an accurate estimate of small signal operation but fall apart at large signal due to the inherent non-linearities associated with large signal systems? Is that a correct inference?
In other words, is it safe to view TS parameters as small signal only? In RF design, we use something called S-parameters to measure the behavior of large signal amplifiers.
They really don't work too well at high power (because they assume a linear system) but they are used as the ideal starting point and then we deviate from there at large signal and start identifying and characterizing the non linear aspects of the model. The approach basically makes it easier to get a handle on a complex, non-linear system.
Sort of. But if you look around you'll see lots of "i measured the parameters of the drivers and they are way differerent than the specs. manufacturers put out garbage data". Part of that could be unit-to-unit variation (which with quality kit can be +/-10% but often reachs much much higher), but most of the time it is that they are measuring on a different part of the curves.
Even a change of the weather can cause significant changes in T/S numbers.
It is likely more the case that if your measures are close to the factories, your drivers have closer to horizontal curves.
dave
Yes
Yes/No, what does your question mean ?
Of course its safe, that doesn't mean its right.
Define what is small signal and what is large ....
What is safe ? and what isn't ....
It doesn't seem relevant at all to me, as your slinging about terms that
might seem clever to you but have nothing to do with speaker design.
I doubt you'll learn sod all about real speaker design airing your opinions
here, you certainly won't learn much in this thread, given that nearly all
information given in threads is contradictory, or is sadly more consistent
marketing speak that really doesn't tell you anything useful or rigourous.
rgds, sreten.
It doesn't seem relevant at all to me, as your slinging about terms thatIn RF design, we use something called S-parameters
I have seen S used in transfer functions... whether it is the same S, i do't know.
dave
Boyton, sorry - I should have remembered. I used to live there, ages ago.The Boynton Beach facility closed years ago. 2,000 or so, especially after the selloff of our mobile phone division to Google.
George is a cool guy, but mostly does amps (at least in public). You can find him here: Tubelab - diyAudio
There goes sreten the pessimist. He thinks some of the stuff i do can't possibly work, and that opinion based on no experience.
You will find lots of opinions, different approaches, differing experiences. And some people, who if the opion, approach, or experience does not align with theirs it has to be wrong (check out the ongoing active vrs passive thread)
So you need to read, sift, make judgements, but most important you need to get your feet wet, to establish a personal experiential reference, and figure out what makes the most sense for you, your room, your kit, your tastes, and your budget.
dave
rgds, sreten.
I disagree. I have already downloaded a few papers that folks here posted for me, as well as ordered two books to help get me started.
Yep, you got the idea.They really don't work too well at high power (because they assume a linear system) but they are used as the ideal starting point and then we deviate from there at large signal and start identifying and characterizing the non linear aspects of the model. The approach basically makes it easier to get a handle on a complex, non-linear system.
Hifi speakers are assumed to be linear, but in the real world, as they reach their limits they go off track. Then there are guitar speakers and some pro audio speakers, which are designed to be non-linear. They deliberately compress as they are driven louder, which provides better performance in a "live" venue, given the way our ears work. Nor are cabinets linear, once you get beyond mini-monitors driven to merely polite volumes. We also can't get away from our listening rooms, and "linear" means something very different to a carpenter.
The Klippel site sreten mentioned earlier is the current state-of-the-art for chasing down false assumptions. But, hey, we had to simplify things to see the basic pattern before complexicating it with all the stuff that really matters. In the '50s, we were so lost....
See this helps a lot. I mentioned the S-parameter thingy, not to clever, but to describe a measurement metric that behaves well at small signal and then craps out fast as non-linearities kick in. So by floating that concept, I was able to get someone with a good understanding of TS to confirm that they behave the same way as something that I personally am quite familiar with. So to that effect, for me, and for my insight, they are relevant to speaker design. Muchos gracias.
dave
Nice line of marketing BS, and you should be ashamed of yourself,
given the real rigour you used to apply when I first joined here.
Utterly stupid argument made above, I have extensive experience
that the claims made are simply hogwash, for the gullible, YMMV.
Nowadays it is all marketing waffle, and this site is losing credibility.
rgds, sreten
Given that the linked thread is so long, i should give away the ending. A number of TLs (3 cabinets, 1 with 3 variations) that do perform very well for this driver combination were developed and an alternate XO offered up. A number of them have been built and the owners are very pleased with the results. Including at least one who had built the original -- he was able to remove the sub he had used to cover off the original's bass deficit.
Revisiting-Thor-291109.pdf
dave
I really like this book. Very comforting reading due to it's simplicity and plain speak.
Good for morning time with a cup of coffee or tea.
http://www.amazon.com/Master-Handbook-Acoustics-Alton-Everest/dp/0071360972
Hi Frankie,
welcome to the forums! I too am an engineer, and like to use my engineering "skills" applied to speakers, but I find that the value of my theoretical understanding often pales compared to the experience of many people here. Both in "real life" and in speakers, I find that just trying stuff gets me a lot further than years of study. But certainly you need a bit of both theoretical understanding and practical knowledge.
There's a lot of good reference material on speaker design, and surely still more progress to be made on the electro-acoustical front --- just look at some of the recent concepts at Danley Sound Labs: the tapped horn and the synergy horn show that bass reflex boxes are definitely not the final stage of evolution for speakers, and there is much more to be learned.
However if I may offer a suggestion counter to many of the popular approaches, I would suggest starting at the other end of the signal chain --- the brain. All speakers are designed with a recipient in mind, a human brain. So viewing the nature of the brain and the ear may reveal more about what traits you want the focus of the design of your speaker to be.
I personally have the book Psychoacoustics by Fastl & Zwicker, which is more or less a reference book of most of our current understanding of psychoacoustics and human auditory perception. It's pretty theoretical, and not directly applicable to speaker design without a few steps of abstraction, but I think the "Munich school of acoustics" is a promising approach in optimizing a speaker to get the best perceived sound. Sure, one could come up with criteria for an ideal speaker without regarding the ear at all --- unity transfer function, dirac impulse response, point source, etc --- but as this perfect speaker is surely not possible in practice, it helps to know which areas you will want to focus on in a compromise design.
Last but not least: experiment. A lot. Build proven designs (Troels Gravesen, Zaph and planet10 come to mind), run simulations (I like HornResp, other popular choices are the MJK worksheets, AkAbak, WinISD Pro and many more), listen to speakers and see for yourself how changes affect the sound. Full range designs are very easy to play around with, you can easily try different enclosure types and compare the effect without having to deal with the crossover at the same time, but they come with their own set of limitations. Even if you don't intend to have a full range as your perfect speaker, there is much to be learned from them.
Enjoy your long road to enlightenment!
- Information on the Physics of Bass Reflex Enclosures
