Information on Tact RCS 2.0 Pre Amp
Does anyone know the connectors used for the RS232 input to the Tact 2.0 ?
I know that one end will be an RS232 but waht cort of plug is used in to the Tact unit itself. I have bought a second hand unit and it does not have this cable and I either need to be able to get a new one or get the pin configuration and get one made in order to use the amp .
Any assistance would be appreciated .
I have found out that this will be an RJ11 - Rs232 Male cable or and no one seems to be sure an RJ12 to RS232 Male cable . Does anyone know of anywhere that still sells this type of cable is used to for old style modem to PC connection until USB became the norm .
Hi Jaycee if I had a cable to take a picture of that would be my problem solved any way . Here are some stock pictures of the RS232 Plug which goes in to the PC and the RJ12 / RJ11 (they both look the same just one has more connected cables than the other ) .
If anyone has one going spare or in the unused cable box then let me know as I will be happy to buy it.
Hi thanks to anyone that has read this thread and offered advice . Glad to say that I have been able tosource a new cable through the UK Agent for Lyngdorf (Gecko Audio) they have a piece in their range of kit that uses the same cable so will be able to order one on Monday.
