information needed...Antique Sound USA PA-3 preamp
Gentlemen
I purchased but haven't received as yet a PA-3 preamp. According to what I have been told it has 3 5814A tubes. It is non-working and I would like to find some information before I tear into it to either gut it and start over or to repair it.
Frank
It looks like I may have to draw up yet another schematic. OH GOD!:bawling: :bawling: :bawling:
Any help or information would be much appreciated.
Joe
Frank
Thanks for trying. I think I will probably scrap the circuit(pc boards) and 12au7's and go for something better. Any ideas on circuit would be appreciated.
Joe
I will draw up the schematic and post it for others to look at before I scrap it.
OH God, another hand drawn schematic :bawling:
I got my preamp today and half the transformer is trashed. I had to disconnect one side of it to remove the short. The reading I took are as follows: orange pair of wires 51volts ac, blue pair of wires 3.2 volts ac, purple pair of wires 121volts ac. I assume I need a transformer with secondaries of 6.3 volts, 100volts, and 240 volts. If this is correct where do I find one?
Joe
Does this sound ample to run 3 5814A's? The listing of tubes says: 12AX7, 12AU7, 6sn7 X 4
The entire tubelisting looks odd to me...
3 x5814 which are just 12Au7S + what? a 12AX7, yet another
12AU7 and than 4 6SN7s?
For a linestage this is rather hard to believe unless some (say 3/4) of the valves are used as regulators...which I somehow feel is quite unlikely...
Back to the drawing board I'd say,😉
Frank
Sorry to confuse you. The information on the transformer states that it can run 12AX7,12AU7, and 6sn7 times four. I would assume it means it has enough guts to run 4 12AX7's or 4 12AU7's or 4 6sn7's.
The preamp I purchased has only 3 5814A's in it so I would assume the transformer should be ample to run it.
Joe
I ran across another preamp with the same schematic as the Antique Sound USA. I will try to attach a schematic.
I am still looking for a schematic for a Antique Sound USA PA-2 Line Preamplifier. I’m tying to confirm the correct designation (4ea) tubes for this Preamp. I found this Preamp for a fair price and I think a rookie tube guy just put whatever tubes he could find and I want to roll the correct tubes into this gear. Your thoughts, experiences and or Docs would be much appreciated, thank you.
