There are a ton of high power subs out there, it really depends on what your budget/enclosure/type of music is and what brands you like.
What you want then, is a low Q driver that can work properly in a small sealed box. They can run a really small box like around 1cf for a 12". Beware of many mass manufacturers that say their sub works in a tiny box, but they really don't. One I have seen is stereointegrity for example, it is made specifically to run a small box and still get low. Idmax is another IIRC, I have used neither. If you have a larger amp then should be no problem getting loud enough for music. The best cheaper one I have used is an mtx 10 that works well in a .8cf sealed, but only a 4500 so only good for 225rms. Ran that on 300rms from a bridged ppi and it worked great, though not as loud as a single 12. You could also build a passive radiator box, they can work really well and be small but I'd go sealed for higher wattage. Any sub is not going to get the bottom in a small sealed, you really need one made for it unless you like really tight booming bass.
