Influence of PS on clock modules
Re: Re: Re: Re: Re: Re: What is more important, crytal module or popwer supply
fmak said:
Elso Kwak said:
Fmak,
Are you referring to this circuit by Cuno Snoeren?
http://www1.tip.nl/~t708955/schem/xoschema.jpg
Yes, also the TL431 Current Regulator configuration. Same order of noise reduction refers.
Hi Fred
Did you (or others) by any chance measure the output noise of that circuit ?
best regards
Re: Re: Re: Re: Re: Re: Re: What is more important, crytal module or popwer supply
Guido Tent said:
Hi Fred
best regards
Yes, in situ in SACD player with supply from 12V regulator; I can get down to about 60 uV with OSCons across LM431, input, and output. I think some of the noise is coming thru' the 7812; really needs separate ps. The player I put this in has a very noisy digital section and power supply.
Guido, have you processed my order yet? Please send an email.
Fred
Re: Re: Re: Re: Re: Re: Re: Re: What is more important, crytal module or popwer supply
Fred
Hi Fred
What is the measurement bandwidth of your instrument ? If it is "infinite", 60 uV is not that bad ......
I will ship tomorrow, I visit he postoffice once a week otherwise It will cot me too much time (people queuing all the time)
best regards
Fred
Hi Fred
Bye the way: What is the regulator noise when not in the circuit ?
Re: Re: Re: Re: Re: Re: Re: Re: Re: What is more important, crytal module or popwer supply
Hi Fred
Bye the way: What is the regulator noise when not in the circuit ? [/B][/QUOTE]
Guido
Not in circuit, around 30 uV. Bandwidth 1MHz, Trio ac voltmeter, unweighted.
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: What is more important, crytal module or popwer supply
fmak said:
Hi Fred
Guido
Not in circuit, around 30 uV. Bandwidth 1MHz, Trio ac voltmeter, unweighted. [/B][/QUOTE]
Hi Fred
Calculation done in my head: That is about 30nV/Sqrrt Hz, not bad !
regards
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: What is more important, crytal module or popwer supply
Guido Tent said:
Guido
Hi Fred
Guido
This took quite a lot of effort; not just connecting up ps to a regulator, and adjustments of decoupling in situ.
Silencing the SACD player (Sony SCDXB940) took much greater effort. I have never seen so many inductors built into the design which unfortunately have multiple grounds and long cable runs to the ps.
Fred
Noise and more Noise
Hii Guido Tent or .
Hola como estas.
Wiich is your opimion in these Graphics;
Jesús:clown:
Re: Noise and more Noise
Jesús Puerto said:
Hii Guido Tent or .
Hola como estas.
Jesús:clown:
Hola Jesús
Estoy bien (I am fine)
Just looked at the graphs. The PLL seems to put out a sine wave, which has more jitter as the input, so I would not use it.
What is the measurement time ? Any info on the spectral content of the distributed noise at the PLL output ?
best regards
More info please
Hi all
Originally posted by Guido Tent:-
Other problems can be taken away by removing the crosstalk to that same supply. For that reason it often helps to seperately supply all servo's (actuator, radial, focus and spindle) in the player, as they induce huge LF currents (Hz - kHz range) in the (often poorly designed) groundplanes.
What is the best way to achieve this?
1. Does one provide separate regulated supplies from the original transformer, for each servo?
OR
2. Does one use a separate transformer for the servo section?
OR
3. Does one use a separate transformer and power supplies for the sensitive stuff (DAC, analogue stage....) and leave the servos to be powered by the original transformer - with separated supplies?
OR
Something else??????
Fin
