Inexpensive B+ Batteries
Switching a bank of batteries from series to parallel could get interesting given that they will all be at slightly different levels of charge.
Nothing like this is impossible, but it doesn't sound very practical on all fronts.
Size doesn't matter. No in this case it really doesn't. If one were to build a rechargeable battery array for B+ (180V or more) what would be the cheapest/most cost effective batteries to use? I don't mind having to make a switch to charge in parallel and discharge in series.
How much current / power ?
If 30w is ok the a 12V lead accu + a dc/dc converter :
DC DC Boost Converter 8 32V 12V to ±45V 390V High Voltage ZVS Capacitor Charging | eBay
this combo will use any 12V power and give an adjustable B+ from 90 to 390V
15 VRLA's of say 3 Ah capacity would cost around £140+ here from a reputable supplier. For the cost and all the hassle you could build a first class mains supply for that.
You can't use a car battery charger on VRLA's though.
