inductor p/s and voltage regulators
It depends. If linear IC, see the manufacturer's recomendation. In general, the larger, the better. For switching, you will need to use several paralleled; for example a 1mF // 47uF // 1uF // .1uF. Mainly if is of the buck and his "sons": This is because the current waveform is a triangle over a rectangle. So large voltage ripples are expected in the bulk storage capacitor.
Just as an example, here is the mfr spec for the LM317.
Driven from a voltage source, input 0.1uF, and outout 1.0uF.
The voltage source also must also deliver the needed current
within the ripple limits for 1/120 seconds, so a certain amount of
bulk input capacitance is also necessary. See post #8.
Your own circuit may vary considerably, but the requirement is there, since a regulator is
a feedback amplifier. Beware of insufficient load capacitance, which might cause instability.
Maybe the Tuba PCB might be slightly illustrative? It's used in SIT / VFET / Ship Of Theseus power amps, to provide clean DC power to two amplifier channels, using a pair of high current voltage regulator chips in an arrangement similar to dual mono. The amp channels are Class A and each one draws about 1.8 amps.
OBTW there's a thread about Tuba here on the Forums.
_
Here is a simplified schematic of the LCL filter that I want to use except for two things: the rectification would be a full wave bridge and there would be no second cap. My goal is to put the v. regulator after the first cap. Is this possible?
