New input transformer, higher than usual output voltage level - check the peak to peak voltage in the 10kHz square graph, 100Ω source, 200k load, no Zobel network whatsoever. In the 10Hz-200kHz sweep graph, level response x2, x4, x6 for the x1 input (green)
Compared with triode 26 (in photo) I think it does about the same thing but with way lower distortion 🙂 - still, not comparing apples with oranges...
This is a test, link to a page, not sure if this forum accepts FB links 🙂
https://www.facebook.com/profile.php?id=100057288107123
Later edit; it seems it works 🙂
