I see both 4 and 5 pin in line bridges. Is there any difference between these and is there any advantage to one type over the other? Thanks
Without us doing research, can you link an example of a 5-pin you mean?
The only 5-pin bridges I myself know of are intended for three-phase power rectification. Like this: http://www.galco.com/techdoc/semj/df100aa160_dat.pdf
These are sold by parts connexion in both hexfred and sic models. They have in line pins for thru hole mounting. Regards
Upon further investigation, it appears that pin three in the five pin array is not connected. It is single phase. Case closed Thanks
