In Bass reflex box (vented)-If I make smaller box than what consequences will I have?
download WINisd pro.
try different volumes and different vent lengths.
You will find that too small a box creates a "hump" in the frequency response. Great if you are using a driver/box that has a very high F3 and you want to create a bass effect by exaggerating the 2nd harmonic. This is very intolerant of room variations and can sound bad on male voice.
A slightly drooping response avoids the bass exaggeration and helps reduce that male voice sensitivity. It is easier to place in the room.
A true "Butterworth" rolloff (Q=1/sqrt(2)) looks nice, but in a room it falls between the two examples above.
That driver is intended for sealed boxes not vented, ~13L stuffed.
But 30L tuned to 33Hz looks good to me, but a big box for a 6.5".
Good bass but limited bass power handing, well suited to valves.
Other options may work better, 30L can take 2 vented 6.5"ers.
rgds, sreten.
Thank you for WINisd pro.
Very usefull program.
I am thinking to use it in a 3-way as woofer 33Hz to 250Hz.
Is it possible this?
Hi, its certainly possible, but it is designed for sealed 2 ways, rgds, sreten.
3 ways are very difficult to design - check out these sites/designs.
Use WinISDPro to model bass max SPL and max bass power handling.
undefinition
Zaph|Audio
FRD Consortium tools guide
RJB Audio Projects
Speaker Design Works
HTGuide Forum - A Guide to HTguide.com Completed Speaker Designs.
Humble Homemade Hifi
DIY Loudspeaker Projects Troels Gravesen
